Maniphest T69061
Convert to mesh doesnt bake instances
Closed, Archived
Philipp Oeser (lichtwerk)
Bob Strang (bobstrang)
Aug 22 2019, 6:47 PM
  • BF Blender
Abid Maqbool (cto.abid)
Operating system: Win 7
Graphics card: nvidia quadro p1000
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)2.8
Convert to mesh did not renew the mesh to a starting point. I performed a dupliface procedure along a curve, https://blenderartists.org/t/b2-8-where-is-duplication-panel-dupliframes-gone/1153070 apploed all mods, converted to mesh, which usually boils everything down to a fresh unlinked mesh, it still keeps parental wiring to the objects I used to make it. All the objects in the array were still considered a linked mesh to the original mesh and when i tried to unparent if from the object that gets arrayed along the curve, it destroys the duplicates along the array, even after applying all mods and converting the mesh.
create curve
create plane
add array mod to plane with x amount and offset
add curve mod to plane
select created curve for the planes array mod
align plane to curve
parent cube to the plane
on the planes object panel under instancing, select faces
select cube
convert to mesh
objects still remain as instances and not baked together to a mesh
-i did find a work around, object/apply/make instances real
is that the preferred method? is it that im not supposed to be able to bake geometry together with convert to mesh?
Bob Strang (bobstrang) created this task.Aug 22 2019, 6:47 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Aug 22 2019, 6:57 PM
Could you post that as a simple .blend file (before converting to mesh)?
(Makes it easier and more effective if multiple devs are looking at the problem, so not everyone has to redo those steps...)
Bob Strang (bobstrang) added a comment.Aug 22 2019, 7:47 PM
oh sure, slipped my mind, here you go
Abid Maqbool (cto.abid) added a subscriber: Abid Maqbool (cto.abid).Aug 23 2019, 9:24 AM
Umm! What you mean, However, find a problem..
  • Open the file & convert the curve to mesh
After converting, still showing curve object here, although its' converted to mesh & no longer usable at this place
Same in 2.81 alpha too.
Abid Maqbool (cto.abid) added a comment.Aug 23 2019, 9:44 AM
@Bob Strang (bobstrang) You wrote, last lines:
select cube
convert to mesh
Cube is already mesh so no need to convert it to mesh...
However, in your case first apply array modifier and then curve modifier.. & let we know
Abid Maqbool (cto.abid) added a comment.Aug 23 2019, 9:46 AM
But to get such a support at https://blender.chat/channel/support. Not looks like bug.
Only i can fine the bug which i mention. however i think, if it's necessary separate report will be made for this.
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Unknown Status.Aug 23 2019, 10:17 AM
  • Yes, convert to mesh applies modifiers internally (but doesnt touch the face instances), so from the single plane, you get a mesh with a bunch of faces on which the instances are still applied as instances
  • To convert the instances to real objects, use make instances real (these can then still be joined together to get a single object)
  • (tiny difference to 2.79: the objects dont automatically get selected after make instances real, see T68191
  • True in a way, the modifier doesnt get tagged as invalid/red, the object is still there, but the curve is gone (making this object invalid for the curve modifier), this could probably be done using DEG_foreach_dependent_ID_component in curvetomesh, but this was also not the case in 2.79 and would not be considered a bug)
That all being said, dont think there is a bug here, closing...
