Maniphest T69294
Add new object
Closed, Duplicate
None
Yuri (Povert)
Aug 29 2019, 2:54 PM
  • BF Blender
Philipp Oeser (lichtwerk)
Yuri (Povert)
Operating system: Linux-5.2.10-arch1-1-ARCH-x86_64-with-arch 64 Bits
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.40
Broken: version: 2.80 (sub 75), branch: makepkg, commit date: 2019-07-29 14:47, hash: rBf6cb5f54494e
If you add a new object, and change the rotation.
The rotation is not working correctly.
X-rotates on the local axis.
Y-rotates on the global axis.
Z-rotates on the global axis.
If Y is a multiple of 90, the local axis of rotation becomes parallel to Z.
Changes X and Z begin to rotate the object by Z.
Similarly, if you add an object in edit mode and change the rotation.
Add a new object.
Try to change the rotation of the object.
The most striking example is if Y is a multiple of 90.
Yuri (Povert) created this task.Aug 29 2019, 2:54 PM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Aug 29 2019, 3:20 PM
I think this is expected behaviour.
In a way this is similar to T68328.
Suggest having a look there (especially the links provided)
Philipp Oeser (lichtwerk) closed this task as a duplicate of T68328: Gizmos in Object Data are not working properly.Aug 29 2019, 3:20 PM
