Maniphest T69343
Models exported using the blender fbx exporter do not react properly to vertex displacement shaders compared to the same meshes exported as Blender OBJ's and fbx's from other programs.
Confirmed, NormalKNOWN ISSUE
None
Eric Jomphe (Velu)
Aug 31 2019, 12:10 AM
  • Import/Export
  • Add-ons (BF-Blender)
  • BF Blender
Eric Jomphe (Velu)
Philipp Oeser (lichtwerk)
Operating system: Windows-10-10.0.16299 64 Bits
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Models exported using the blender fbx exporter do not react properly to vertex displacement shaders compared to the same meshes exported as Blender OBJ's and fbx's from other programs. None of the export options work to fix this issue including changing the scale parameters, unit scale and toggling apply unit.
The mesh is the proper size, but the vertices are overreacting to vertex displacement shaders as if the scale was much larger than it actually is. In the attached zip, I included a video, the original blend file, the blender fbx and obj exports as seen in the video as well as a 3ds max export for comparison. Notice that the 3ds max export when imported into blender has the correct size but a scale of 0.010, This is after a reset xform (the max equivalent of an apply transforms).
Load included blend file. Export as FBX , import into Unity and apply vertex displacement, compare with OBJ export or fbx export from other programs.
Related Objects
Eric Jomphe (Velu) created this task.Aug 31 2019, 12:10 AM
Philipp Oeser (lichtwerk) edited projects, added Add-ons (Community), Import/Export; removed BF Blender.Nov 20 2019, 12:52 PM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Known Issue".May 27 2020, 4:21 PM
Bastien Montagne (mont29) added a project: Python API.
Bastien Montagne (mont29) mentioned this in T68575: FBX Known issues & TODO's.
Campbell Barton (campbellbarton) moved this task from Backlog to Under Discussion on the Python API board.Jun 18 2020, 3:13 PM
Campbell Barton (campbellbarton) removed a project: Python API.Jun 18 2020, 3:48 PM
Campbell Barton (campbellbarton) moved this task from Backlog to Bugs (BF-Blender) on the Add-ons (Community) board.Jun 19 2020, 9:10 AM
Campbell Barton (campbellbarton) edited projects, added Add-ons (BF-Blender); removed Add-ons (Community).Jun 19 2020, 12:00 PM
Campbell Barton (campbellbarton) moved this task from Backlog to Long Term on the Add-ons (BF-Blender) board.Jun 22 2020, 7:17 AM
Campbell Barton (campbellbarton) added a project: BF Blender.Jun 22 2020, 7:21 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Jun 22 2020, 1:04 PM
I havent checked this myself, but from the report history, I assume this can be confirmed?
