Maniphest T69376
Wireframe node still not working in Eevee for Mac OSX
Closed, Duplicate
None
Harry Boteler (hboteler)
Sep 1 2019, 1:34 PM
  • BF Blender
dark999 (dark999)
Philipp Oeser (lichtwerk)
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Harry Boteler (hboteler) created this task.EditedSep 1 2019, 1:34 PM
Wireframe node not working in Eevee for Mac OSX
Tried it on latest 2.81 build (2019/09/01). This was reported some time ago but still has not been fixed
dark999 (dark999) added a subscriber: dark999 (dark999).Sep 1 2019, 1:52 PM
How developers can reproduce your problem and solve it?
You forgot to upload a simplest possible .blend file to reproduce this propblem, just as you forgot to fill relevant data as request in bug template
The operating system, main memory size, GPU brand and model, GPU driver version and Blender hash or its build date may be needed by developers to investigate this problem
You can check [[ https://www.blender.org/download/requirements/ | here ]] if your hardware and software meet minimum Blender requirement
thank you
Harry Boteler (hboteler) added a comment.Sep 2 2019, 11:01 AM
Here's a simple 2.81 blend file showing wireframe node not working in Eevee:
Mac details: MacOS Mojave (v10.14.6); Retina 5K; Radeon Pro 580 (8 GB)
Blender 2.81 (Build 2019/09/01)
I hope this helps
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Sep 2 2019, 4:09 PM
Cannot reproduce on linux.
@Harry Boteler (hboteler): report already open is probably this T68843 (you can also try looking for the duplicates prior to opening a new report).
Will merge these reports...
Philipp Oeser (lichtwerk) closed this task as a duplicate of T68843: Invalid (pink) shader when using wireframe node [ Eevee ].Sep 2 2019, 4:09 PM
