Maniphest T69966
Repeatable crash with mesh.bevel operator
Closed, Archived
Bastien Montagne (mont29)
eldee smith (eldee)
Sep 17 2019, 5:57 AM
  • BF Blender
eldee smith (eldee)
Jacques Lucke (JacquesLucke)
tom k (tomjk)
Graphics card: GeForce GTX 1050 Ti with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70
This is an odd one, and took me over a week of hammering on it to come up with a 100% repro. At first it seemed totally random, as I had artists in my studio reporting random crashes after beveling and watched it happen a few times with no clear common denominator, but the crash always happens at the exact same address:
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF799F33F35
Module : c:\_workdir\blender-2.80\blender.exe
The terminal process terminated with exit code: 11
These are the exact steps you will need to repro (I've demonstrated it in the attached video as well).
  1. Open the attached .blend
  2. Select an edge
  3. Run the mesh.bevel operator
  4. Check the "Loop Slide" option in the operator panel (i'm not sure if the option you choose matters, but it does matter that you change one of the settings in the operator panel)
  5. Undo without committing the operation
  6. DESELECT and then RE-SELECT the same edge (this is important, if you fail to do this the crash will not happen).
  7. Run the mesh.bevel operator again
  8. Check or Uncheck the "Loop Slide" option (whatever the opposite state it's in)
  9. Undo without committing the operation
  10. Crash at Address : 0x00007FF799F33F35
Related Objects
eldee smith (eldee) created this task.Sep 17 2019, 5:57 AM
eldee smith (eldee) mentioned this in T66772: Bevel Modifier Crash.Sep 17 2019, 6:06 AM
tom k (tomjk) added a subscriber: tom k (tomjk).EditedSep 17 2019, 6:48 PM
Cannot reproduce here.
Operating system: Linux-4.15.0-55-generic-x86_64-with-debian-stretch-sid 64 Bits
Blender: 2.80 and latest master
Please check if the problem has been fixed for you since 2.80:
  • Download the latest build from http://builder.blender.org.
  • Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue.
eldee smith (eldee) added a comment.Sep 17 2019, 8:38 PM
Well, I'll post an update whenever either the 2.81 download finishes (it's been going for about 2 hours now, previous attempts have timed out) or the build I just started finishes.
In the meantime, here's a video of it happening with default settings in 2.80 final:
eldee smith (eldee) added a comment.Sep 17 2019, 9:09 PM
Good news, does not appear to be happening on the build I just made- so it may have been fixed by something else. I'll hammer on it for a bit longer and see if I can get it to break
eldee smith (eldee) added a comment.Sep 17 2019, 10:13 PM
Scratch that- not happening in edge mode, but I was able to repro it in face mode. Since I went through the trouble of building Blender I went ahead and made a debug build to get a callstack, this is the output:
blender.exe!issue_debug_notification(const wchar_t * const message) Line 28
at minkernel\crts\ucrt\src\appcrt\internal\report_runtime_error.cpp(28)
blender.exe!__acrt_report_runtime_error(const wchar_t * message) Line 154
at minkernel\crts\ucrt\src\appcrt\internal\report_runtime_error.cpp(154)
blender.exe!abort() Line 61
at minkernel\crts\ucrt\src\appcrt\startup\abort.cpp(61)
blender.exe!CustomData_get_layer_index(const CustomData * data, int type) Line 2065
at c:\blender-git\blender\source\blender\blenkernel\intern\customdata.c(2065)
blender.exe!CustomData_has_layer(const CustomData * data, int type) Line 2509
at c:\blender-git\blender\source\blender\blenkernel\intern\customdata.c(2509)
blender.exe!bpy_bmesh_dealloc(BPy_BMesh * self) Line 3452
at c:\blender-git\blender\source\blender\python\bmesh\bmesh_py_types.c(3452)
[External Code]
blender.exe!BPY_DECREF_RNA_INVALIDATE(void * pyob_ptr) Line 583
at c:\blender-git\blender\source\blender\python\intern\bpy_interface.c(583)
blender.exe!WM_operator_free(wmOperator * op) Line 78
at c:\blender-git\blender\source\blender\windowmanager\intern\wm.c(78)
blender.exe!WM_operator_stack_clear(wmWindowManager * wm) Line 184
at c:\blender-git\blender\source\blender\windowmanager\intern\wm.c(184)
blender.exe!ed_undo_exec(bContext * C, wmOperator * op) Line 389
at c:\blender-git\blender\source\blender\editors\undo\ed_undo.c(389)
blender.exe!wm_operator_invoke(bContext * C, wmOperatorType * ot, wmEvent * event, PointerRNA * properties, ReportList * reports, const bool poll_only, bool use_last_properties) Line 1451
at c:\blender-git\blender\source\blender\windowmanager\intern\wm_event_system.c(1451)
blender.exe!wm_handler_operator_call(bContext * C, ListBase * handlers, wmEventHandler * handler_base, wmEvent * event, PointerRNA * properties) Line 2279
at c:\blender-git\blender\source\blender\windowmanager\intern\wm_event_system.c(2279)
blender.exe!wm_handlers_do_keymap_with_keymap_handler(bContext * C, wmEvent * event, ListBase * handlers, wmEventHandler_Keymap * handler, wmKeyMap * keymap, const bool do_debug_handler) Line 2581
at c:\blender-git\blender\source\blender\windowmanager\intern\wm_event_system.c(2581)
blender.exe!wm_handlers_do_intern(bContext * C, wmEvent * event, ListBase * handlers) Line 2718
at c:\blender-git\blender\source\blender\windowmanager\intern\wm_event_system.c(2718)
blender.exe!wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Line 2977
at c:\blender-git\blender\source\blender\windowmanager\intern\wm_event_system.c(2977)
blender.exe!wm_event_do_handlers(bContext * C) Line 3464
at c:\blender-git\blender\source\blender\windowmanager\intern\wm_event_system.c(3464)
blender.exe!WM_main(bContext * C) Line 420
at c:\blender-git\blender\source\blender\windowmanager\intern\wm.c(420)
blender.exe!main(int argc, const unsigned char * * UNUSED_argv_c) Line 493
at c:\blender-git\blender\source\creator\creator.c(493)
[External Code]
eldee smith (eldee) added a comment.Sep 17 2019, 10:15 PM
Here's a video of it happening in face mode with the latest from git.
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 30.Sep 18 2019, 12:30 PM
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
I cannot reproduce it either.
Please clarify what you mean by "committing the operation" and "undo without committing the operation".
Furthermore, please prepare a new file in which you can reproduce the crash with as few steps as possible.
eldee smith (eldee) added a comment.Sep 18 2019, 5:32 PM
committing the operation- when the operator is no longer running modal and has returned. in other words- while the operator panel with all of the operator properties is still visible.
I'll try, but as you can see in the video above it's happening on the default cube with factory defaults restored. Not sure how much simpler I can make it than that :)
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).Oct 1 2019, 10:10 PM
Cannot reproduce either here on linux with current master. Your crashlog is weird too, since it seems to go through py API of bmesh when freeing operator, that does not make much sense as bevel is a C op… What is the operator in the WM_operator_free() call in that stack when the crash happen?
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Oct 14 2019, 11:42 AM
