Maniphest T69979
Make "offset edge loop" slide evenly
Confirmed, LowTO DO
Sebastian Parborg (zeddb)
Vyacheslav (hitrpr)
Sep 17 2019, 2:06 PM
  • BF Blender
  • Modeling
Jacques Lucke (JacquesLucke)
Martin Capitanio (capnm)
Paul Kotelevets (1D_Inc)
Piotr Adamowicz (madminstrel)
Vyacheslav (hitrpr)
Tokens
"Like" token, awarded by brezdo."Like" token, awarded by hitrpr."Like" token, awarded by 1D_Inc."Like" token, awarded by fiendish55."Like" token, awarded by capnm.
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Just repeat the video example
Revisions and Commits
Vyacheslav (hitrpr) created this task.Sep 17 2019, 2:06 PM
Jacques Lucke (JacquesLucke) added a project: Modeling.Sep 17 2019, 4:13 PM
Jacques Lucke (JacquesLucke) added subscribers: Campbell Barton (campbellbarton), Jacques Lucke (JacquesLucke).
I can reproduce it, but I'm not sure if this is a bug.
@Vyacheslav (hitrpr) what would you expect exactly?
@Campbell Barton (campbellbarton) should this work differently?
Vyacheslav (hitrpr) added a comment.Sep 17 2019, 4:43 PM
@Jacques Lucke (JacquesLucke)
I expect even distance between edges. the same way as solidify do it, for example.
even edge offset literally: edge offset from edge, not vertex from vertex as it is now.
Not a bug but wrong behaviour, as I think.
Martin Capitanio (capnm) added a subscriber: Martin Capitanio (capnm).Sep 18 2019, 3:06 AM
Seems to be a creative cover for 'offset edge loops slide' aka 'offset edge slide' aka [shift-ctrl + r], an implementation that has always worked this way.
Campbell Barton (campbellbarton) renamed this task from Offset edge loop cut do not make even spaces to Make "offset edge loop" slide evenly.Sep 18 2019, 3:18 AM
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to Low.
Campbell Barton (campbellbarton) mentioned this in T63731: Modeling Module.
Campbell Barton (campbellbarton) edited a custom field.
Campbell Barton (campbellbarton) added a comment.Sep 18 2019, 3:24 AM
This isn't a bug, although this could be supported.
Note that making the offset "even" can cause spikes, so we'd want this to be an option - as it is for shrink/fatten "offset even" option.
Martin Capitanio (capnm) added a comment.Sep 18 2019, 3:59 AM
Offset "even" doesn't help with the OP-selected geometry:
Campbell Barton (campbellbarton) added a comment.Sep 18 2019, 4:09 AM
These are two different kinds of even.
  • The existing option moves a fixed distance from one side of the edge loop.
  • The other option (which this report is asking for) would increase the offset based on the angle between the edges.
Martin Capitanio (capnm) awarded a token.Sep 18 2019, 6:17 PM
Mikail (fiendish55) awarded a token.Sep 26 2019, 2:31 PM
Paul Kotelevets (1D_Inc) awarded a token.Sep 29 2019, 7:06 PM
Vyacheslav (hitrpr) awarded a token.Oct 4 2019, 8:30 AM
Mateusz (brezdo) awarded a token.Nov 5 2019, 6:14 PM
Mateusz (brezdo) added a subscriber: Mateusz (brezdo).
Paul Kotelevets (1D_Inc) added a subscriber: Paul Kotelevets (1D_Inc).Nov 22 2019, 2:48 PM
Yeah, one of the most needed functionality considering edge slide, alongside with edge flow and curvature support.
Piotr Adamowicz (madminstrel) added a subscriber: Piotr Adamowicz (madminstrel).Jan 17 2020, 8:49 AM
This comment was removed by Piotr Adamowicz (madminstrel).
Germano Cavalcante (mano-wii) mentioned this in T68836: Transform Refactoring.Apr 3 2020, 9:48 PM
Mateusz (brezdo) removed a subscriber: Mateusz (brezdo).May 18 2020, 3:32 PM
Campbell Barton (campbellbarton) moved this task from Backlog to Long Term on the Modeling board.Jun 17 2020, 4:53 AM
Campbell Barton (campbellbarton) moved this task from Long Term to Todo (Mesh Editing) on the Modeling board.Jun 17 2020, 4:56 AM
Campbell Barton (campbellbarton) moved this task from Todo (Mesh Editing) to Todo (Transform) on the Modeling board.Jun 17 2020, 5:04 AM
Sebastian Parborg (zeddb) claimed this task.Jul 17 2020, 6:45 PM
