Maniphest T70000
very long operator name crashes upon addon activation
Closed, Resolved
Jacques Lucke (JacquesLucke)
Jakub Uhlik (carbon14)
Sep 18 2019, 1:28 AM
  • BF Blender
Brendon Murphy (meta-androcto)
Jesse Yurkovich (deadpin)
Operating system: Darwin-16.7.0-x86_64-i386-64bit 64 Bits
Graphics card:
install example addon, try to enable in preferences
Related Objects
Mentioned In
T101803: Max length Operator bl_idname is truncated 1 character
Mentioned Here
rB4e9aadac5e77: Fix T70033: Crash editing keymap operator
Jakub Uhlik (carbon14) created this task.Sep 18 2019, 1:28 AM
Brendon Murphy (meta-androcto) added subscribers: Campbell Barton (campbellbarton), Brendon Murphy (meta-androcto).Sep 18 2019, 10:39 AM
@Campbell Barton (campbellbarton) this seems a little like a forced error, users should not do this nor expect it to work. It deliberately defies pep8 just to prove a point.
Unfortunately it's a real thing I guess, so users should be prevented from taking this action?
Jacques Lucke (JacquesLucke) changed the task status from Unknown Status to Resolved.Sep 18 2019, 11:27 AM
Jacques Lucke (JacquesLucke) claimed this task.
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
I get the following error message:
  File "/Text", line 31, in <module>
  File "/Text", line 22, in register
RuntimeError: Error: Registering operator class: 'EXAMPLE_OT_some_quite_a_long_name_for_an_operator_to_handle_and_a_bit_more_characters_to_make_sure_it_crashes', invalid bl_idname 'example_ops.some_quite_a_long_name_for_an_operator_to_handle_an', is too long, maximum length is 61
This is a perfectly valid limitation imo (could be improved in the future, but I don't see a big benefit).
This is not a bug in Blender but in the addon.
Jesse Yurkovich (deadpin) added a subscriber: Jesse Yurkovich (deadpin).Sep 18 2019, 11:38 AM
I get a crash here. How did you try the addon? I did a real Install from preferences and then attempted to enable it, leading to the following.
The stack based idname_bl array has been overrun:
Run-Time Check Failure #2 - Stack around the variable 'idname_bl' was corrupted.
blender.exe!WM_operatortype_find(const unsigned char * idname, bool quiet) Line 90	C
blender.exe!rna_Operator_register(Main * bmain, ReportList * reports, void * data, const unsigned char * identifier, int(*)(PointerRNA *, void *, int *) validate, int(*)(bContext *, PointerRNA *, FunctionRNA *, ParameterList *) call, void(*)(void *) free) Line 1506	C
blender.exe!pyrna_register_class(_object * UNUSED_self, _object * py_class) Line 8630	C
[External Code]
blender.exe!bpy_class_call(bContext * C, PointerRNA * ptr, FunctionRNA * func, ParameterList * parms) Line 8313	C
blender.exe!rna_operator_execute_cb(bContext * C, wmOperator * op) Line 1299	C
blender.exe!wm_operator_invoke(bContext * C, wmOperatorType * ot, wmEvent * event, PointerRNA * properties, ReportList * reports, const bool poll_only, bool use_last_properties) Line 1451	C
blender.exe!wm_operator_call_internal(bContext * C, wmOperatorType * ot, PointerRNA * properties, ReportList * reports, const short context, const bool poll_only, wmEvent * event) Line 1652	C
blender.exe!WM_operator_name_call_ptr(bContext * C, wmOperatorType * ot, short context, PointerRNA * properties) Line 1701	C
blender.exe!ui_apply_but_funcs_after(bContext * C) Line 845	C
blender.exe!ui_handler_region_menu(bContext * C, const wmEvent * event, void * UNUSED_userdata) Line 10222	C
blender.exe!wm_handler_ui_call(bContext * C, wmEventHandler_UI * handler, const wmEvent * event, int always_pass) Line 622	C
blender.exe!wm_handlers_do_intern(bContext * C, wmEvent * event, ListBase * handlers) Line 2731	C
blender.exe!wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Line 2977	C
blender.exe!wm_event_do_handlers(bContext * C) Line 3356	C
blender.exe!WM_main(bContext * C) Line 420	C
Jacques Lucke (JacquesLucke) added a comment.Sep 18 2019, 11:47 AM
I can reproduce the crash when the addon is loaded (I just run it in the text editor).
While this can be considered a security issue in Blender (due to the buffer overflow), we generally cannot avoid security issues when people run arbitrary Python code.
Addons resulting in a crash, because they use the Python API incorrectly, is generally not considered to be a bug in Blender.
Campbell Barton (campbellbarton) added a comment.Sep 23 2019, 5:37 AM
Fixed the crash rB4e9aadac5e7756b0bf3d313ec31cc85770347b8a
