Maniphest T70064
Mute RGB to BW converter node doesn't work in Cycles rendered
Closed, Duplicate
None
Emmanuel LORANT (asturias)
Sep 19 2019, 11:51 AM
  • Cycles
  • BF Blender
Brecht Van Lommel (brecht)
Clément Foucault (fclem)
Jacques Lucke (JacquesLucke)
Philipp Oeser (lichtwerk)
tom k (tomjk)
Operating system: Windows 10 x64
Graphics card: 1060 + 1080 Ti
Broken: Last one : blender-2.81-741d7d60ed90-windows64
(example: 2.79b release)
As title says
Create a new material with a RGB to BW node. Mute it. It works in Look Dev mode, not in Rendered mode with Cycles (it works with EEVEE).
Emmanuel LORANT (asturias) created this task.Sep 19 2019, 11:51 AM
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 50.Sep 19 2019, 12:18 PM
Jacques Lucke (JacquesLucke) edited projects, added Cycles, BF Blender; removed Add-ons (Community).
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Sep 19 2019, 12:32 PM
Can confirm.
tom k (tomjk) added a subscriber: tom k (tomjk).EditedSep 19 2019, 12:33 PM
Example file:
Looks to affect pretty much any node that has colour or colour-like (i.e. vector) inputs and non-colour output.
edit: Apologies, does not affect normal map and vector displacement (muting pulls value from a different input).
Jacques Lucke (JacquesLucke) added subscribers: Clément Foucault (fclem), Brecht Van Lommel (brecht), Jacques Lucke (JacquesLucke).Sep 19 2019, 12:35 PM
Ah, actually, I'm not sure if this is a bug in eevee or Cycles. Although, the eevee solution seems more useful.
Consider this setup:
Cycles replaces the internal link with a convert node that converts the Color input to the Value output. This happens to work the same as RGB to BW apparently.
However, eevee does this:
So it does not convert the color to an intermediate BW value.
I still consider this a bug, because Cycles and eevee should work the same in this regard.
@Brecht Van Lommel (brecht), @Clément Foucault (fclem) should Cycles or eevee be changed here?
