Maniphest T70323
The Grease Pencil glow effect holds out the stroke, even if the stroke is being obscured
Closed, Duplicate
None
ogierm
Sep 28 2019, 1:02 PM
  • BF Blender
  • Grease Pencil
Antonio Vazquez (antoniov)
Gloria (GloriaTheAnimator)
ogierm
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.30
Broken: version: 2.81 (sub 12), branch: master, commit date: 2019-09-27 22:44, hash: rB1c1a3198af9d
At first I thought that the effect doesn't care if the part of the stroke is actually visible or not, but that isn't the case: if you hide a GP object in another object it will disappear.
What I think is happening is that the effect holds out areas where there would be a stroke, but that check doesn't include whether or not that part of the stroke is actually being drawn (because it is obscured). I think the screenshots and the file might demonstrate it better.
All of the other effects seem to respect the geometry of the scene properly, so I think this is a bug and not a technical limitation.
  1. Add a Grease Pencil object.
  2. Add some geometry that obscures it
  3. Add the Glow effect
ogierm created this task.Sep 28 2019, 1:02 PM
ogierm updated the task description.
ogierm added a project: Grease Pencil.
ogierm updated the task description.Sep 29 2019, 3:01 PM
Germano Cavalcante (mano-wii) assigned this task to Antonio Vazquez (antoniov).Oct 1 2019, 7:26 PM
Germano Cavalcante (mano-wii) lowered the priority of this task from 90 to 50.
Dalai Felinto (dfelinto) removed Antonio Vazquez (antoniov) as the assignee of this task.Dec 23 2019, 1:49 PM
Dalai Felinto (dfelinto) added a project: Tracker Curfew.
Dalai Felinto (dfelinto) added a subscriber: Antonio Vazquez (antoniov).
Antonio Vazquez (antoniov) closed this task as a duplicate of T66293: GPencil: Redesign Blend modes and cleanup Drawing Engine.Dec 28 2019, 9:54 AM
Antonio Vazquez (antoniov) removed a project: Tracker Curfew.
Gloria (GloriaTheAnimator) added a subscriber: Gloria (GloriaTheAnimator).Aug 4 2020, 11:28 PM
how did you add the glow effect i need this?
Antonio Vazquez (antoniov) added a comment.Aug 5 2020, 9:08 AM
@Gloria (GloriaTheAnimator) You need go to the VFX panel. To display the effect, be sure to be in Render mode.
