Maniphest T70351
vertex slide always uses increment snapping instead of what's selected in the snap options.
Closed, Archived
Germano Cavalcante (mano-wii)
michael campbell (3di)
Sep 29 2019, 11:58 AM
  • BF Blender
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86
set vertices as the snap option, shift+v or GG, then slide trying to snap to another vertex. The snap appears to snap to increments instead. Or is there some way you can lock the direction line angle, and then the snap works?
michael campbell (3di) created this task.Sep 29 2019, 11:58 AM
michael campbell (3di) added a comment.Sep 29 2019, 12:07 PM
actually i've just found a way of locking the direction angle line. You just press C to clamp after you have the dashed angle line correctly set so that all verts move along the intended edges. After this I thought it might revert to the selected snap type, but it's still using incremental.
I think after clamp has been activated, then the active vert should slide along the edge its clamped to until it's in line with the target vert. The non active verts should slide along their clamped edges by the same distance, either relative to their edge length, or by the same value.
Germano Cavalcante (mano-wii) changed the task status from Unknown Status to Unknown Status.Oct 1 2019, 8:52 PM
Germano Cavalcante (mano-wii) claimed this task.
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).
This is a known limitation.
There are plans to support this. See:
T66426: Edge and Vertex sliding: snapping improvements
