Maniphest T70668
Regression: Cycles Viewlayer - Holdout not renderable without casting shadows and reflections
Closed, DuplicateTO DO
None
Marcus Papathoma (machieb)
Oct 9 2019, 10:51 AM
  • BF Blender
  • Cycles
Brecht Van Lommel (brecht)
Daniele De Luca (sparazza)
Philipp Oeser (lichtwerk)
Rainer Trummer (aliasguru)
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.02
Broken: version: 2.81 (sub 14), branch: master, commit date: 2019-10-08 22:16, hash: rB0812949bbc3d
Worked: 2.79b
In Blender 2.79b it was possible to have a holdout (mask layer) and exclude it form illumination
This was the renderlayer config
This isn´t possible in 2.8x anymore.
In 2.8x the object that is masked (holdout) is always used in illumination calculation.
Rendering from 2.81
You see the reflection and the shadow of the red masked cube.
Both following viewlayer configurations do the same.
If you think logical, the configuration in the last image should not calculate illumination for this viewlayer, because indirect illumination is off!
If holdout and indirect only are off the layer is calculated normal.
If holdout is on then indirect only off/on should have an effect! **
Open the attached blend file for blender 2.8
Activate Vieport rendering
You see that the red cube is masked out but shadows and reflections are calculated for it on the other cubes. Activate Indirect only next to the holdout icon in the outliner.
Nothing happens.
Open the attached blend file for blender 2.79b.
Click on Render > Render Image
You get this result. No reflection and no shadow from the masked cube.
Deaktivate Exclude for layer three in the layer tab.
Render the image again. As expected the masked cube is calculated and casts shadows and reflections on the other cubes.
Marcus Papathoma (machieb) created this task.Oct 9 2019, 10:51 AM
Rainer Trummer (aliasguru) added a subscriber: Rainer Trummer (aliasguru).Oct 9 2019, 1:15 PM
Marcus Papathoma (machieb) renamed this task from Regression: Cycles Viewlayer - Holdout not renderable without casting shadows and casting reflections to Regression: Cycles Viewlayer - Holdout not renderable without casting shadows and reflections.Oct 9 2019, 1:41 PM
Marcus Papathoma (machieb) updated the task description.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to Normal.Oct 10 2019, 4:14 PM
Philipp Oeser (lichtwerk) added subscribers: Brecht Van Lommel (brecht), Philipp Oeser (lichtwerk).
There were T66362 and T66004 and if I understand correctly, this is a known limitation atm.
In T66362#713396, @Brecht Van Lommel (brecht) wrote:
The behavior regarding exclude is a known limitation at the moment, there is a comment in the code about it. The dependency graph does not evaluate the excluded objects at all so this requires a different design.
@Brecht Van Lommel (brecht): do you want to keep this one task open for this?
I will put this on Normal prio as TODO type, but feel free to close if this is on the radar anyways...
Philipp Oeser (lichtwerk) edited a custom field.Oct 10 2019, 4:14 PM
Philipp Oeser (lichtwerk) added a project: Cycles.
Brecht Van Lommel (brecht) closed this task as a duplicate of T66362: Does not work when collection 'holdout' is set to 'indirect only'.Oct 10 2019, 4:20 PM
Daniele De Luca (sparazza) added a subscriber: Daniele De Luca (sparazza).Jul 13 2021, 11:46 PM
