Maniphest T70828
Object Wireframe disappear when armature bone is selected in edit mode
Closed, Resolved
Jacques Lucke (JacquesLucke)
Wayne Dixon (waylow)
Oct 15 2019, 7:30 AM
  • BF Blender
  • Platform: macOS
FabianSchempp (FabianSchempp)
mw (fuchsundbaer)
Richard Antalik (ISS)
Operating system: Darwin-17.2.0-x86_64-i386-64bit 64 Bits
Graphics card: NVIDIA GeForce GTX 1050 Ti OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-10.27.6 378.10.10.10.20.109
Broken: version: 2.82 (sub 0), branch: master, commit date: 2019-10-14 19:07, hash: rB9a85592ddea2
If you have the wires visible on a mesh object and then select a bone in edit mode on an armature object, the wireframe disappears.
This makes it hard to position the bones effectively.
This may be related to https://developer.blender.org/T67831 as it occurs under the same circumstances as when the navigation icons disappear.
add mesh object and enable wires in viewport visibility
add armature
switch to edit mode for that armature
as soon as you select a bone - the wires on the mesh object are no longer visible
Related Objects
Wayne Dixon (waylow) created this task.Oct 15 2019, 7:30 AM
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 80.Oct 15 2019, 9:51 AM
Jacques Lucke (JacquesLucke) added a project: Platform: macOS.
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
I agree that might be related T67831. I cannot reproduce it because I don't have macOS.
FabianSchempp (FabianSchempp) added a subscriber: FabianSchempp (FabianSchempp).Oct 19 2019, 12:06 PM
I might have found a related problem in Blender 2.81 beta on Mac OS X, Graphic Card: Intel Iris Graphics 6100. When selecting a bone in Editmode ALL MESHES disappear (and the viewport navigation icons as well)
FabianSchempp (FabianSchempp) added a comment.Oct 19 2019, 12:12 PM
I can reproduce and confirm the behavior of the original report.
with the wire_frame_not_visible.blend file in blender 2.81 beta.
Wireframe and navigation Icons dissapear when selecting bone in editmode.
FabianSchempp (FabianSchempp) added a comment.EditedOct 19 2019, 12:17 PM
I just found out, that disabeling "outline" in the viewport shadeing dropover, makes the whole mesh disappear. That was my initial problem.
mw (fuchsundbaer) added a subscriber: mw (fuchsundbaer).Oct 19 2019, 6:03 PM
Richard Antalik (ISS) changed the task status from Needs Information from Developers to Needs Information from User.Jan 14 2020, 9:16 PM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
@Wayne Dixon (waylow) Is this still an issue with latest build? https://builder.blender.org/download/
Wayne Dixon (waylow) added a comment.Jan 15 2020, 4:46 AM
I think this might be fixed ;)
-The icons no longer disappear
-The meshes don't disappear when you select bones in edit mode
-same for if you turn off the 'outline selected'
I'm noticing some other weird drawing errors with wireframe shading and x-ray toggled on, however, I think this is a different issue so I'll post that in a different report when I can chance to narrow in on how to replicate it efficiently.
Jacques Lucke (JacquesLucke) closed this task as Resolved.Jan 15 2020, 10:42 AM
Jacques Lucke (JacquesLucke) claimed this task.
