Maniphest T71005
Blender 2.81 crashes frequently on assigning material
Closed, Resolved
Philipp Oeser (lichtwerk)
Jacek Podkanski (bigos)
Oct 21 2019, 10:15 PM
  • BF Blender
noki paike (amonpaike)
pat (pat)
Pinus
Operating system: Linux
Graphics card: GeForce GT 730/PCIe/SSE2
version: 2.81 (sub 15), branch: master, commit date: 2019-10-20 15:47, hash: 71538eaad66b, type: Release
Blender frequently crashes on assigning materials
I have started from the original cube for the exact steps see the screencast:
https://www.youtube.com/watch?v=pwjvGWfwOSM
crash happens at 4:12
Related Objects
Mentioned In
T71080: Crash on adding material - Linux
Mentioned Here
rB71538eaad66b: Fix T70864: Separate loose parts runs indefinitely
Jacek Podkanski (bigos) created this task.Oct 21 2019, 10:15 PM
Pinus added a subscriber: Pinus.EditedOct 22 2019, 1:48 AM
Do you render with GPU or CPU?
Does blender crash when you set CPU for render?
It seems like you're "out of memory" on GPU and/or System (PC or Notebook)
try running blender with --debug-gpu-force-workarounds => and start Blender again.
noki paike (amonpaike) added a subscriber: noki paike (amonpaike).EditedOct 22 2019, 1:58 AM
which linux, on mesa or proprietary drivers?
edit the bug report with:
open blender-> menu -> help -> report a bug
blender will tell you about which machine you are and what drivers you use.
Jacek Podkanski (bigos) added a comment.Oct 22 2019, 7:42 AM
Operating system: Linux-4.15.0-65-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GT 730/PCIe/SSE2 NVIDIA Corporation 4.4.0 NVIDIA 340.107
Broken: version: 2.81 (sub 15), branch: master, commit date: 2019-10-20 15:47, hash: rB71538eaad66b
Jacek Podkanski (bigos) added a comment.Oct 22 2019, 8:20 AM
When I was playing with manual retopology and tried to add material to the wrapping object it crashed again with the following log:
jacek@jacek-ixtreme-M5850:~/Downloads/blender-2.81-71538eaad66b-linux-glibc217-x86_64$ ./blender --debug-gpu-force-workarounds
Read prefs: /home/jacek/.config/blender/2.81/config/userpref.blend
Received X11 Error:
	error code:   8
	request code: 154
	minor code:   34
	error text:   BadMatch (invalid parameter attributes)
GPU: Bypassing workaround detection.
GPU: OpenGL identification strings
GPU: vendor: NVIDIA Corporation
GPU: renderer: GeForce GT 730/PCIe/SSE2
GPU: version: 4.4.0 NVIDIA 340.107
Received X11 Error:
	error code:   8
	request code: 154
	minor code:   34
found bundled python: /home/jacek/Downloads/blender-2.81-71538eaad66b-linux-glibc217-x86_64/2.81/python
Received X11 Error:
	error code:   8
	request code: 154
	minor code:   34
Received X11 Error:
	error code:   8
	request code: 154
	minor code:   34
Received X11 Error:
	error code:   8
	request code: 154
	minor code:   34
Received X11 Error:
	error code:   8
	request code: 154
	minor code:   34
Received X11 Error:
	error code:   8
	request code: 154
	minor code:   34
Received X11 Error:
	error code:   8
	request code: 154
	minor code:   34
Skipping auto-save, modal operator running, retrying in ten seconds...
Received X11 Error:
	error code:   8
	request code: 154
	minor code:   34
Received X11 Error:
	error code:   170
	request code: 154
	minor code:   5
	error text:   GLXBadContext
X Error of failed request:  GLXBadContext
  Major opcode of failed request:  154 (GLX)
  Minor opcode of failed request:  5 (X_GLXMakeCurrent)
  Serial number of failed request:  406081
  Current serial number in output stream:  406081
Jacek Podkanski (bigos) added a comment.Oct 22 2019, 9:29 AM
Trying recommended Nvidia driver for Ubuntu does n't seem to have the problem,
the log:]
GPU: version: 4.5.0 NVIDIA 430.26
Saved session recovery to '/tmp/quit.blend'
Blender quit
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved.Oct 22 2019, 11:02 AM
I guess this can be closed then? [since we have a working driver?]
(feel free to comment again though if issues arise again...)
pat (pat) added a subscriber: pat (pat).Jan 1 2020, 1:49 AM
HI,
I ve got the same config (ubuntu NV 730GT ...) , and passed from 340.107 that crached blender -> to nvidia 390 ... driver and worked fine on every 2.80 2.81 and 2.82 , (in the additional drivers ubuntu directly in software and updates == easiest way to install the nvidia drivers)
used this one because the last driver 435 from nvidia website don't work correctly on my old config (wrong resolution, don't detect my vga screen any more)
if other drivers don't work u can also set rendering to CPU & "supported" features ... and works fine (but without CPU+GPU performance)
the error logfile was looking some thing like segmentation fault... before stoping app and was happening at any time while using blender 3d...
thanks for this topic that helped me to solve my problem.
Bye
