Maniphest T71084
Grease pencil transparency issue over Camera Background Image
Closed, DuplicateBUG
None
Luciano Muñoz Sessarego (looch)
Oct 25 2019, 2:53 AM
  • BF Blender
  • Grease Pencil
  • EEVEE & Viewport
Antonio Vazquez (antoniov)
Clément Foucault (fclem)
Philipp Oeser (lichtwerk)
Operating system: Linux-3.10.0-693.21.1.el7.x86_64-x86_64-with-centos-7.4.1708-Core 64 Bits
Graphics card: Quadro M5000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 396.54
Broken: version: 2.82 (sub 1), branch: master, commit date: 2019-10-24 19:11, hash: rB2a3b5dc73038
Grease pencil has weird edges when put over a Camera Background Image (it doesnt happen over an image texture)
Create a new 2D animation file
drag and drop an image to the viewport to get it as a background image
draw on top of it.
see the white borders around the drawing?, its much worse when the strenght of the pencil is driven by pressure or when the strength is not 100 percent.
here are some samples
Related Objects
Mentioned Here
rB84bf68186dfe: Merge branch 'greasepencil-object' into greasepencil-refactor
T66293: GPencil: Redesign Blend modes and cleanup Drawing Engine
Luciano Muñoz Sessarego (looch) created this task.Oct 25 2019, 2:53 AM
Luciano Muñoz Sessarego (looch) added a project: Grease Pencil.Oct 25 2019, 5:25 AM
Antonio Vazquez (antoniov) added a subscriber: Antonio Vazquez (antoniov).Oct 25 2019, 8:42 AM
I guess this is related to T66293
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Dec 28 2019, 11:17 PM
@Antonio Vazquez (antoniov) : should we merge this into T66293 then?
note: at the current state of https://developer.blender.org/diffusion/B/history/greasepencil-refactor/ (rB84bf68186dfe) this does not seem to be solved there...
Antonio Vazquez (antoniov) added a subscriber: Clément Foucault (fclem).EditedDec 29 2019, 8:56 AM
@Philipp Oeser (lichtwerk) Not sure. I keept this task because I don't know if this must be fixed in GP Drawing Engine or it's in other drawing areas.
@Clément Foucault (fclem) What do you think?
BTW: The refactoring is in progress and still a lot of things pending.
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".Jan 15 2020, 4:16 PM
Bastien Montagne (mont29) added a project: EEVEE & Viewport.
Antonio Vazquez (antoniov) added a comment.Jan 27 2020, 11:45 AM
Tested and fixed in refactored engine.
Antonio Vazquez (antoniov) closed this task as a duplicate of T66293: GPencil: Redesign Blend modes and cleanup Drawing Engine.Jan 27 2020, 11:46 AM
