Maniphest T71381
Offse Edge Slide doesn't save redo options correctly
Closed, Duplicate
None
Stanislav Blinov (radcapricorn)
Nov 6 2019, 11:29 AM
  • BF Blender
Philipp Oeser (lichtwerk)
Broken: 2.8x
After performing the interactive Offset Edge Slide, the options you've chosen do not seem to be represented in the Redo panel. For example, if Even is enabled while modal operator is running, the "Even" checkbox will not be enabled in the panel after you confirm the operator.
  1. Load the .blend
  2. Enter edit mode
  3. Activate Offset Edge Slide (ctrl+shift+r)
  4. Activate the Even option (e)
  5. Move the mouse and click to confirm
  6. Show the redo panel
The "even" option in the panel will not be checked.
Stanislav Blinov (radcapricorn) created this task.Nov 6 2019, 11:29 AM
Stanislav Blinov (radcapricorn) added a comment.Nov 6 2019, 12:14 PM
Could be related to T71295, seeing as in both cases these are macros.
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Nov 6 2019, 1:32 PM
This the same as T45964: Edge/Vert Slide fail to properly "redo", will merge these reports...
Philipp Oeser (lichtwerk) closed this task as a duplicate of T45964: Edge/Vert Slide fail to properly "redo".Nov 6 2019, 1:33 PM
