Maniphest T71389
Lookdev HDRIs are interpreted incorrectly when using different colour spaces
Confirmed, NormalKNOWN ISSUE
None
Sam Van Hulle (sam_vh)
Nov 6 2019, 7:28 PM
  • BF Blender
  • EEVEE & Viewport
Jeroen Bakker (jbakker)
Jose (Dogway)
Operating system: Any
Graphics card: Any
Broken: 2.82 (sub 1), branch: master, commit date: 2019-11-04 20:01, hash: ef7fd50f8a93, type: Release
HDRIs installed into Blender for use in Lookdev Mode don't offer an option to set their colour space.
  • Blender probably assumes they are encoded in Rec.709, but this doesn't hold up if they're not.
  • Alternatively, when using a different OCIO config, the Rec.709 colour space is almost never listed as just 'Linear', so Blender picks a different space from the config.
Both scenarios cause undesired hue shifts. This is most probably also true for MatCaps, but to be fair I haven't looked yet into how they work.
  1. Install a differently encoded HDRI into Blender, for example one of the EXRs from the imageworks/OpenColorIO-Configs repo on GitHub.
  2. Switch the viewport to lookdev mode and activate the newly installed HDRI. The colours will have shifted.
or:
  1. Start Blender using an alternate OCIO config, such as one from said imageworks/OpenColorIO-Configs repo.
  2. Switch the viewport to lookdev mode and try the HDRIs that ship with Blender by default. Those colours will also have shifted.
Sam Van Hulle (sam_vh) created this task.Nov 6 2019, 7:28 PM
This is probably best avoided by looking up roles instead of literal colour space names.
Sam Van Hulle (sam_vh) mentioned this in T68926: Color Management Improvements.Nov 6 2019, 7:31 PM
Jeroen Bakker (jbakker) added a subscriber: Jeroen Bakker (jbakker).Nov 7 2019, 9:51 AM
Seems to be related to the color management issues described by T71357: Design: DrawManager Colormanagement
Sam Van Hulle (sam_vh) added a comment.Nov 7 2019, 1:39 PM
I think it's more superficial than that. Lookdev Mode to me seems like a temporary World that Blender creates and tells Eevee to use while the Viewport is in that mode. In that case this World uses an environment texture like any other World does, only without the amount of controls we normally would be presented with.
Jeroen Bakker (jbakker) added a project: GPU / Viewport.EditedJan 20 2020, 3:12 PM
Jeroen Bakker (jbakker) changed the subtype of this task from "Report" to "Known Issue".
Color management hasn't been added to the World textures. This needs additional design and thoughts as there is no place to select/store the color space. So I will set this to Known Issue for now.
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Jan 20 2020, 11:31 PM
Jose (Dogway) added a subscriber: Jose (Dogway).Mar 9 2020, 7:26 PM
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport.Jun 19 2020, 10:23 PM
Clément Foucault (fclem) moved this task from Backlog to Known Issues on the EEVEE & Viewport board.Jul 1 2020, 7:32 PM
