It happens since years ago but I never report it. Blender have few coherence between the way that snap to face with "Project Individual Elements" on.
- Move: You snap when you move the mesh (correct), you don't snap with Ctrl pressed
- Rotate: You don't snap when you rotate, You snap when you hold the Ctrl key (incorrect)
- Scale: You don't snap when you scale, You snap when you hold the Ctrl key (incorrect)
- Edge slide: Snap doesn't work properly. slide make little jumps, if you press Ctrl then the movement is smooth but the snap still not working properly.
Use any mesh like "high poly" and try to retopo with snap to faces on and "project individual elements" on
