Maniphest T71655
Simplify F-Curves doesn't work with tiny objects
Closed, Resolved
Vladimir Spivak (cwolf3d)
Christoph Werner (Taros)
Nov 18 2019, 12:35 PM
  • Add-ons (Community)
Philipp Oeser (lichtwerk)
Operating system: Windows
Graphics card: GeForce 1080Ti
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: f6cb5f54494e,
build date: 2019-07-29, 09:44 AM
Simplify F-Curves seem not to work with very tiny objects.
I've a small medaillon, that is just 10 centimeters wide. There is a small animated bird inside.
Simplify F-Curves doesn't work, even when I set an error value of "0.00001".
The result: The curves are completely cleaned and became nearly straight lines after simplifying them.
Note: All works fine with big sized objects in meters. So there seem to be a problem with the decimal places value.
I've verified this issue in the following situation:
I've scaled my object 10 times as big, and the Addon worked then.
So please correct this great tool to use it with very tiny models too.
Animation curves can't be scaled proportionally, while objects are scaled as I know.
Thank you
@Philipp Oeser (lichtwerk)
Revisions and Commits
rBA Blender Add-ons
Related Objects
Christoph Werner (Taros) created this task.Nov 18 2019, 12:35 PM
Philipp Oeser (lichtwerk) edited projects, added Add-ons (Community); removed BF Blender.Nov 18 2019, 12:50 PM
Vladimir Spivak (cwolf3d) claimed this task.Nov 18 2019, 1:07 PM
Vladimir Spivak (cwolf3d) changed the task status from Unknown Status to Resolved by committing rBAb2b2c2b8c12b: Fix T71655, T71656: Removed it from the channel menu. I extended the addon….Nov 19 2019, 1:04 AM
Vladimir Spivak (cwolf3d) added a commit: rBAb2b2c2b8c12b: Fix T71655, T71656: Removed it from the channel menu. I extended the addon….
burger@wiredworks.com (martburg) mentioned this in D9754: Simplify Curves not working on Drivers !.Dec 5 2020, 11:45 AM
