Maniphest T71678
Rigify doesn't generate if advanced option is set to "new"
Closed, Resolved
Alexander Gavrilov (angavrilov)
Ivan Cappiello (icappiello)
Nov 19 2019, 5:11 PM
  • Add-ons (Community)
Brendon Murphy (meta-androcto)
Damien Picard (pioverfour)
Nathan Letwory (jesterking)
Toni Alatalo (antont)
Operating system: Darwin-19.0.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) Iris(TM) Graphics 6100 Intel Inc. 4.1 INTEL-14.0.69
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-12 13:28, hash: rB125257758007
Worked: 2.80
When rigify advanced generate options are set to "new" rig, the generate function will raise error.
• Add a human metarig from the Add Menu
• In Armature panel, under "Rigify Buttons" panel click on "Advanced Options" to activate the options panel
• Set the generate option to "New" and insert a name in the "Rig Name" field
• Click on "Generate Rig" Button
Rigify will raise the error:
'Generation has thrown an exception: name 'obj' is not defined'
Related Objects
Mentioned Here
rBAed5b81f501ea: Fix T71678: Rigify crash if the Advanced mode is set to New.
rBA3423174b37a0: Rigify: redesign generate.py and introduce a base rig class.
Ivan Cappiello (icappiello) assigned this task to Alexander Gavrilov (angavrilov).Nov 19 2019, 5:11 PM
Ivan Cappiello (icappiello) created this task.
Ivan Cappiello (icappiello) edited projects, added Add-ons (Community); removed BF Blender.
Ivan Cappiello (icappiello) added a subscriber: Damien Picard (pioverfour).Nov 26 2019, 11:54 AM
seems that merged patch by @Damien Picard (pioverfour) Rigify: store advanced options in armature instead of window manager fixes it for 2.82.
still there are some minor issues relative to naming and python ui.
  • the patch removes the '_rig' suffix from rig name, still this name is retained for the python ui script: Creating a rig with no name should roll back to default 'rig' as rig name and should logically output 'rig_ui.py'. If advanced option is set to "new" and a new name is set (for example 'new') the python ui script should named accordingly (new_ui) but will instead still append '_rig_ui' to the name. The python ui script and the rig should have consistent names.
  • If options is set to new and no name is set, generate will roll back to use 'rig' as name. if another rig is present in the scene a new 'rig.001' is created but the associated ui will be 'rig_ui.py.001' instead of 'rig.001_ui.py'
Damien Picard (pioverfour) added a subscriber: Nathan Letwory (jesterking).Nov 26 2019, 2:52 PM
This bug was introduced by rBA3423174b37a0.
@Alexander Gavrilov (angavrilov) It seems that a 2.81a release is planned, should the fix be backported before then? @Nathan Letwory (jesterking) said “If we do we may wait some extra days to see if any other pressing issue is found”, but I don’t know if this qualifies as a pressing issue.
@Ivan Cappiello (icappiello) You are right about the Python script’s name, for it to be registrable, it must end with .py. Perhaps it should just use the generated rig’s name, something like:
diff --git a/rigify/rig_ui_template.py b/rigify/rig_ui_template.py
index bb5a9cbd..e9168483 100644
--- a/rigify/rig_ui_template.py
+++ b/rigify/rig_ui_template.py
@@ -1163,9 +1163,13 @@ class ScriptGenerator(base_generate.GeneratorPlugin):
         # Generate the UI script
         if metarig.data.rigify_rig_basename:
-            rig_ui_name = metarig.data.rigify_rig_basename + '_rig_ui.py'
+            rig_ui_name = self.generator.obj.name + '_rig_ui.py'
         else:
             rig_ui_name = 'rig_ui.py'
+            i = 1
+            while rig_ui_name in bpy.data.texts:
+                rig_ui_name = 'rig_ui.%03i.py' % i
+                i += 1
         script = None
About the _rig_ui vs _ui issue, it doesn’t bother me too much, I feel _rig_ui is more descriptive.
Ivan Cappiello (icappiello) added a subscriber: Brendon Murphy (meta-androcto).EditedNov 26 2019, 3:03 PM
i already wrote @Brendon Murphy (meta-androcto) and this could eventually be included in 2.81a
i don't agree. If you remove the _rig suffix from generated rig name for a reason, the same reason applies to python ui script. Please make tools consistent. Either you remove _rig from both or you leave it both places.
Alexander Gavrilov (angavrilov) added a comment.Nov 26 2019, 10:03 PM
This is a simple editing mistake that happened when splitting a huge function into class methods:
--- a/rigify/generate.py
+++ b/rigify/generate.py
@@ -114,7 +114,7 @@ class Generator(base_generate.BaseGenerator):
         self.widget_collection = ensure_widget_collection(context)
         # Remove wgts if force update is set
-        wgts_group_name = "WGTS_" + (self.rig_old_name or obj.name)
+        wgts_group_name = "WGTS_" + (self.rig_old_name or self.obj.name)
         if wgts_group_name in scene.objects and id_store.rigify_force_widget_update:
             bpy.ops.object.mode_set(mode='OBJECT')
             bpy.ops.object.select_all(action='DESELECT')
Alexander Gavrilov (angavrilov) changed the task status from Unknown Status to Resolved.Dec 3 2019, 11:32 AM
Fixed for 2.81a in rBAed5b81f501ea4.
Toni Alatalo (antont) added a subscriber: Toni Alatalo (antont).Dec 3 2019, 3:19 PM
Hi, little nitpick, meant just as a friendly note:
  1. Those are not class methods but instance methods (refer 'self', not 'cls'). Python has also class methods, but they seem to not be used there.
  1. I think a Python Linter would catch such errors, kind of like a compiler, note that 'obj' is unknown there. Maybe helpful to use as a part of the Blender Python workflow somehow
