Maniphest T71778
proportional editing
Closed, Archived
Philipp Oeser (lichtwerk)
robert (bobcat)
Nov 22 2019, 1:26 PM
  • BF Blender
robert (bobcat)
Stanislav Blinov (radcapricorn)
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.64
robert (bobcat) created this task.Nov 22 2019, 1:26 PM
robert (bobcat) added a comment.Nov 22 2019, 1:32 PM
proportional editing stopped working I can only move 1 vert. at a time and mouse wheel won't scroll after grabbing vert. I have tried other settings but nothing helps. I also uninstalled program then did new install and nothing changed.
Stanislav Blinov (radcapricorn) added a subscriber: Stanislav Blinov (radcapricorn).Nov 22 2019, 1:54 PM
Please provide a sample .blend file where this behavior can be observed.
Stephen Swaney (stiv) mentioned this in T71777: proportional edit not working.Nov 22 2019, 3:55 PM
robert (bobcat) added a comment.Nov 24 2019, 2:57 PM
robert (bobcat) added a comment.Nov 26 2019, 11:51 AM
when trying to use proportional editing I can grab only 1 verticies at a time instead of a group as in tutorial 2 of the doughnut. the tool will work as long as I don't change the size and shape as in same tutorial.
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Archived.Dec 5 2019, 1:46 PM
Thx for the report.
Looks like you are hitting G again (this will go into Vertex Slide[GG], which is different from normal G...)
From the video I cannot see a bug, you select one vertex, grab with proportional ON (but Proportional Size is at 1.0 -- very big for a small object like yours, try lowering it with the Mouse wheel, you should see the circle indicating the approximate area of influence going down -- thus all vertices are moving). Then it seems you are hitting G again, thats why you are in another tool then [Vertex Slide].
Try the above suggestions, this looks very much like an issue of how to use blender (rather than a bug). For help using Blender, please try one of the community websites: https://www.blender.org/community/
Will archive this, feel free though to comment again if issues persist...
