Maniphest T71809
Alt_gr(Ctrl+Alt) is not working in the Text Editor
Closed, Resolved
Peter Fog (tintwotin)
Nov 23 2019, 9:30 AM
  • BF Blender
  • Text Editor
Matjaž Lamut (lamoot)
Philipp Oeser (lichtwerk)
Graphics card: Intel(R) UHD Graphics 600 Intel 4.5.0 - Build 26.20.100.7158
Broken: version: 2.82 (sub 1), branch: master (modified), commit date: 2019-11-22 06:23, hash: rB3d015c71ccbc
On a danish keyboard you'll have press Alt_Gr(or Ctrl+Alt) + 8/9 to make square brackets. In the text entry boxes in Blender this works correctly, but not in the Text Editor, where Alt_gr has no effect at all, making it impossible to make much needed square brackets:
Related Objects
Peter Fog (tintwotin) assigned this task to Campbell Barton (campbellbarton).Nov 23 2019, 9:30 AM
Peter Fog (tintwotin) created this task.
Peter Fog (tintwotin) added a project: Text Editor.
Matjaž Lamut (lamoot) added a subscriber: Matjaž Lamut (lamoot).Nov 23 2019, 5:35 PM
I can't reproduce this bug. I can type the brackets with a danish keyboard and my default (slovenian) keyboard, which also uses AltGr for [] brackets.
I tested this on Windows 10 64bit
Blender 2.82 (sub 1), branch: master, commit date: 2019-11-22 18:14, hash: 373e936e3e64
Peter Fog (tintwotin) added a comment.Nov 23 2019, 7:03 PM
If you look at the gif above, you'll see that it is working normally in text entry boxes, but pressing the same buttons in the text editor, nothing happens... so there must be a difference in how key presses are used.
Matjaž Lamut (lamoot) added a comment.Nov 23 2019, 8:52 PM
I'm not saying there is no issue, as the gif indeed clearly shows this. However, it's not straight-forward to replicate the bug, so the cause must be something more specific. On my end, the brackets worked in the entry box as well as in the text editor.
Does the same problem appear for you in official 2.81 release, or the earlier 2.80?
In addition, does the problem appear even after restoring default settings (File -> Defaults -> Load Factory Settings)?
Germano Cavalcante (mano-wii) removed Campbell Barton (campbellbarton) as the assignee of this task.Nov 26 2019, 6:42 PM
Germano Cavalcante (mano-wii) lowered the priority of this task from 90 to 30.
Germano Cavalcante (mano-wii) added a subscriber: Campbell Barton (campbellbarton).
Peter Fog (tintwotin) added a comment.Nov 26 2019, 6:53 PM
It may be the same bug as this: https://developer.blender.org/T66607
but affecting all characters where Alt_gr is needed.
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Dec 5 2019, 3:55 PM
Please check these, so we can t proceed with this report...
Peter Fog (tintwotin) changed the task status from Unknown Status to Resolved.Dec 6 2019, 10:34 PM
Peter Fog (tintwotin) claimed this task.
It seems to be caused by an add-on. I notified the coder of the add-on.
