Maniphest T71889
The Boolean Modifier has it's settings mixed up when compared to their functions.
Closed, Archived
Anthony Edlin (krash)
Junaid Hossain Efaj (Phil_Violated)
Nov 25 2019, 2:48 PM
  • BF Blender
  • Modeling
Operating system: Windows 10
Graphics card: Nvidia Geforce 940mx
Broken: 2.80
When using the boolean operation, in some of my recent projects, I've noticed that the settings provided by the boolean operation is all messed up. For example, I wanted to use the difference operation, but blender decided to use Union operation.
And when I set the operation to Union, it performed the Difference Operation. I'm still not sure about the intersection operation yet.
Bonus: If you decide to perform boolean with an object with more than one "sub-object" (as in an object consisting of 2 cubes or such),
then blender would apply the boolean operation to one of the sub-object and won't do the same for the other unless you connect their vertices in edit mode.
Junaid Hossain Efaj (Phil_Violated) created this task.Nov 25 2019, 2:48 PM
Anthony Edlin (krash) added a subscriber: Anthony Edlin (krash).Nov 25 2019, 5:07 PM
Hi, thanks for the report.
I can't reproduce what you describe wrong with booleans on a simple file. Can you share as simple file as possible that demonstrates the issue you are having? Also you can check with 2.81 and a nightly build here and see if it works.
Maciej Jutrzenka (Kramon) added a project: Modeling.Nov 25 2019, 8:46 PM
Junaid Hossain Efaj (Phil_Violated) added a comment.Nov 26 2019, 5:48 PM
Well sorry if my bug description was too vague, but I'll send both a screenshot and a project file. And yes, I was working on 2.81.
This screenshot is just an example of one instance of the bug where it happened on its own.
File link: https://drive.google.com/open?id=1nDC_SBzJqW8xet3eIZACvgyXuEznzJdW
And as for that one "bonus" bug, I don't seem to be able to recreate it like I could yesterday.
But I'll keep you informed if I manage to bump into it again.
Anthony Edlin (krash) changed the task status from Unknown Status to Unknown Status.Nov 26 2019, 10:06 PM
Anthony Edlin (krash) claimed this task.
Thanks for the file. When I check your file you can see that the wall section you are trying to boolean is not solid. It seems maybe there was already a boolean applied or intersected on inside half of wall mesh. If I fix this and make the section just a plain wall face, and I also make it more manifold by added a face to the bottom, then this is the result I get:
There are real issues with booleans in blender given the implementation, but in this case I think it's responding reasonably.
Going to archive this for now.
