Operating system: Windows 10
Graphics card: Nvidia Geforce GT 220
Broken: (2.81)
Worked: (2.80)
while applying textures to objects some random faces were disappearing from the veiwport, and in Renders without using any Transparent textures. each time i apply a different texture different faces disappear, it only happens on objects with multiple textures applied
with the default cube in edit mode i added a single loop cut to each edge and then bevelled them all, i then extruded those bevelled faces in by pressing e then s. i created 2 textures in the properties menu ( one is a black metallic shader, the other was a plain white shader) i applied the second texture to the inset faces and they proceed to vanish.
