Maniphest T71992
Object disappears in Sculpt Mode
Closed, Duplicate
None
John (generic.fit)
Nov 28 2019, 2:15 AM
  • BF Blender
  • Platform: macOS
  • EEVEE & Viewport
John (generic.fit)
Philipp Oeser (lichtwerk)
Operating system: Mac OS Mojave
Graphics card: None
Broken: v 2.81
Object breaks/disappears using Dynotopo in Sculpt mode after a minute or so. I still see the Dynotopo dots and brush snapping to the invisible form but no object. It’s happened more than once and within the first minutes of sculpting.
Sculpt in Dynotopo (Constant Detail/Smooth Shading/12 Resolution) and the object disappears within a minute or two for me. I’m confident I’m not hitting anything by mistake and I can’t find a way to remedy it.
John (generic.fit) created this task.Nov 28 2019, 2:15 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Nov 28 2019, 2:22 PM
Philipp Oeser (lichtwerk) added projects: GPU / Viewport, Platform: macOS.
To really progess further here, we would need your full specs.
Help > Save System Info
It might also help checking if this is the same problem as T71147: 2.81 & 2.82 Eevee stops rendering in Rendered and Look Dev modes in viewports (macOS):
  • does this happen in solid viewport shading as well?
  • if you have a chance to check if this is reproducable on another machine, that could help as well... [preferably non MacOS]
And to make sure we are all on the same page:
  • please provide an example blend file where this happens
John (generic.fit) added a comment.Nov 29 2019, 12:06 AM
Thank you, Philipp,
Yes, the bug is exactly the same as the one in the link you provided—I apologize for the redundancy.
Solid viewport shading isn’t working, but if I switch over to Cycles, my object appears. Eevee will work again if I save, close the file, and reopen.
I only have access to a Mac at the moment. Here is my system-info.txt file.
Have a great holiday, you all are magic!
John{F8176391}
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport.Jun 19 2020, 11:04 PM
