Maniphest T72138
Crashing when scene doesn't have meshes and using command searcher, 100% repro
Closed, Duplicate
None
nameless (tonpix)
Dec 3 2019, 9:30 AM
  • BF Blender
Dalai Felinto (dfelinto)
nameless (tonpix)
Nathan Letwory (jesterking)
Philipp Oeser (lichtwerk)
Sergey Sharybin (sergey)
Operating system: Windows 10
Graphics card: Nvidia GTX1080
Broken: (example: 2.81 official stable release
Worked: (optional): Blender 2.82 Alpha - December 03, 00:20:54 - 1e480840a212
Blender crashes when scene doesn't have any meshes (no cube) and when you use command searcher (F3 default hotkey) in 2 possible ways to cause Blender crash.
One way:
  1. Open default scene, delete Cube
  2. Open command searcher (F3 key), type "e", then "x" - on that last key Blender should crash
Other way:
Same as above, except instead pressing "x" key, scroll down to list bottom. When it reaches end of list, it crashes Blender
Out of curiosity, checked 2.82 alpha version and there were no issues
I've attached .blend file where I was testing crashing. But just deleting all meshes in your default startup scene should do the trick. I've asked in Blender discord and one person confirmed crashing.
Can I hope for fix before 2.82? :D
Related Objects
Mentioned Here
T71932: Crash when type "ext" in search
rB1e480840a212: Overlay: Fix vertex discard issue on Nvidia hardware
nameless (tonpix) created this task.Dec 3 2019, 9:30 AM
nameless (tonpix) updated the task description.Dec 3 2019, 9:34 AM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Dec 3 2019, 9:48 AM
This was fixed, see T71932: Crash when type "ext" in search.
And you already noted, that this works fine in 2.82 alpha, so... not sure what you are asking?
Yes, 2.82 alpha daily builds...
Philipp Oeser (lichtwerk) closed this task as a duplicate of T71932: Crash when type "ext" in search.Dec 3 2019, 9:48 AM
nameless (tonpix) added a comment.Dec 3 2019, 10:31 AM
I meant to ask if this could be hotfixed in 2.81. Especially if there's already an fix. 2.82 alpha isn't production ready and it will be months before reaching this point. Thanks.
Philipp Oeser (lichtwerk) added subscribers: Sergey Sharybin (sergey), Dalai Felinto (dfelinto), Nathan Letwory (jesterking).Dec 3 2019, 10:37 AM
No, no backport fixes.
2.82 is scheduled for February.
There will be a 2.81a bugfix release soonish though, we might consider to include this fix in there as well?
CC @Nathan Letwory (jesterking) , @Dalai Felinto (dfelinto), @Sergey Sharybin (sergey)?
