Maniphest T72460
Transform: Tilt values in curves are not transformed
Confirmed, LowTO DO
None
Vic Jeong (smartmon)
Dec 15 2019, 12:04 PM
  • BF Blender
  • Modeling
Germano Cavalcante (mano-wii)
Philipp Oeser (lichtwerk)
2.8, 2.81
When mirroring curves, tilt values are not mirrored.
In edit mode, MIRROR(or SCALE -1) dose not change tilt values.
So I can not get mirrored result (bebel geometry).
(In object mode, I can get mirrored 2 curves by MIRROR(or SCALE -1),
But JOIN the two curves results not mirrored tilt effect.)
Open:
  • The file contains 2 splines. One is a scaled duplicate of the other.
  • Note that the tilt of the corresponding point remains the same on both splines.
Vic Jeong (smartmon) created this task.Dec 15 2019, 12:04 PM
Vic Jeong (smartmon) updated the task description.Dec 15 2019, 12:06 PM
Vic Jeong (smartmon) updated the task description.Dec 16 2019, 1:34 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Dec 16 2019, 1:52 PM
Unsure if I understand correctly:
  • is this about the mirrir modifier?
  • is this about mirroring in objectmode?
  • is this about mirroring in editmode?
Above file has a path mirrored in objectmode and negated tilt (by hand). Dont think this would be expected default behavior?
Possibly I am misunderstanding, but in order to proceed here, we would need an example .blend file with exact steps to reproduce (and an explanation of what the expected [vs. the actual] behavior would be...)
Vic Jeong (smartmon) renamed this task from tilt values are not mirrored to tilt values are not mirrored (in edit mode).Dec 17 2019, 1:02 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Needs Triage.Jan 7 2020, 9:47 AM
Germano Cavalcante (mano-wii) renamed this task from tilt values are not mirrored (in edit mode) to Transform: Tilt values in curves are not transformed.Jan 8 2020, 2:47 PM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.
Germano Cavalcante (mano-wii) triaged this task as Low priority.
Germano Cavalcante (mano-wii) updated the task description.
Germano Cavalcante (mano-wii) added a project: Modeling.
Germano Cavalcante (mano-wii) changed the subtype of this task from "Report" to "To Do".Jan 8 2020, 2:49 PM
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).
Although it would be interesting to support, this is not a bug.
But I'll put it as To Do to be revisited another day.
Germano Cavalcante (mano-wii) mentioned this in T68836: Transform Refactoring.Jan 8 2020, 2:50 PM
Germano Cavalcante (mano-wii) mentioned this in T63731: Modeling Module.Jan 29 2020, 5:57 PM
Campbell Barton (campbellbarton) moved this task from Backlog to Todo (Transform) on the Modeling board.Jun 17 2020, 5:07 AM
