Maniphest T72478
3D Viewports broken on OSX
Closed, Archived
Jean First (robbott)
Jarkko Kainulainen (Semperdux)
Dec 16 2019, 5:09 PM
  • BF Blender
  • EEVEE & Viewport
dupoxy (dupoxy)
Operating system: OSX Mojave 10.14.6
Graphics card: AMD Radeon R9 M390 2 GB
Broken: Version 2.81 (2.81 2019-11-20)
Worked: Version 2.80
3d viewports are completely broken on OSX.
  • Wireframe doesn't work. Only shows outline of the mesh.
  • Objects are culled behind each other in wireframe mode
  • Material preview doesn't show any meshes
  • Eevee doesn't render any meshes in viewport
  • Solid mode doesn't show wireframe
  • Meshes cannot be selected from viewport. Lights and cameras can be selected. Sometimes curves can be selected sometimes not.
  • Curves do not appear at all not even in edit mode
Blender practically became impossible to use after 2.81 because of this. I have tried everything and haven't found a fix for this.
  • I have re-installed Blender 2.81 multiple times
  • I have restored factory settings
  • This problem appeared with Blender 2.81 and got worse with the latest OSX update.
  • The problem doesn't go away by tweaking any settings or selecting different options for viewports.
  • Sometimes when you have two 3d viewports on the screen at the same time on of them works and one doesn't
Open Blender -> Broken
Alternatively: Open Blender -> Add meshes and add materials -> Broken
Sometimes viewports work for a while. Sometimes restarting blender helps for a second. After you select a mesh from viewport for the first time it usually gets broken right away.
I have the same problem on 2 different iMacs. The other one is the lates iMac PRO so this is not just an individual driver problem.
Jarkko Kainulainen (Semperdux) created this task.Dec 16 2019, 5:09 PM
Jarkko Kainulainen (Semperdux) updated the task description.
Robert Guetzkow (rjg) renamed this task from 3dViewports broken on OSX to 3D Viewports broken on OSX.Dec 16 2019, 6:16 PM
Robert Guetzkow (rjg) added a project: GPU / Viewport.
dupoxy (dupoxy) added a subscriber: dupoxy (dupoxy).Dec 16 2019, 6:26 PM
Jarkko Kainulainen (Semperdux) added a comment.Dec 17 2019, 12:17 AM
Looks like that fixes it. Thank you so much. I'll keep testing it and let you know if I find some problems.
Jean First (robbott) changed the task status from Unknown Status to Unknown Status.Dec 17 2019, 2:16 AM
Jean First (robbott) claimed this task.
Jean First (robbott) added a subscriber: Jean First (robbott).
Closing it for now.
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport.Jun 19 2020, 11:03 PM
