Maniphest T72539
Boolean swap UV's in alphabetical order
Closed, Duplicate
None
Michael Soluyanov (crantisz)
Dec 18 2019, 9:49 AM
  • BF Blender
  • Modifiers
Chris Clyne (lateasusual)
Operating system: Linux-4.15.0-72-generic-x86_64 Ubuntu 18.04 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken: version: 2.81a, 2.82 (sub 5), branch: master, commit date: 2019-12-16 23:15, hash: rB1ef6be368683
If you have an object with 2 UV's with non-default naming (for example UVMap.001, UVMap instead UVMap, UVMap.001 ), boolean modifier will swap UVs in alphabetical order.
  • Open the file. Note, that the cube has 2 UVs one of them rotated at 45deg.
  • Disable boolean modifier - UV will change.
  • note, if UVs have default order boolean modifier will not swap UVs
Michael Soluyanov (crantisz) created this task.Dec 18 2019, 9:49 AM
Chris Clyne (lateasusual) added a subscriber: Chris Clyne (lateasusual).Dec 18 2019, 8:55 PM
I'm not sure if this is the intended behaviour, but it's because the boolean target object also has named UVmaps that don't match, not alphabetical ordering. If you add UVMap.001, UVMap to the white cube in that order, the target UV's won't change over.
Won't mark as closed since like I said I don't know if this is by design.
Germano Cavalcante (mano-wii) added a project: Modifiers.Dec 19 2019, 4:08 PM
