Maniphest T72716
Blender RigidBody Physics broken
Closed, Archived
Philipp Oeser (lichtwerk)
Tohny (Tohny)
Dec 27 2019, 12:30 AM
  • BF Blender
  • Physics
Tohny (Tohny)
Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66
CPU: R5 2600
RAM: 16GB DDR4
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash: rBf1aa4d18d49d
Objects fly away when I click play{F8245480}
Tohny (Tohny) created this task.Dec 27 2019, 12:30 AM
Tohny (Tohny) added a project: Physics.
Philipp Oeser (lichtwerk) closed this task as Archived.Dec 28 2019, 12:50 PM
I would not call this broken [2.79 behave the same way here]
Those spiky colliders are not always easy to set up, but here are a couple of things to consider:
  • have an eye on the collision margins [in your case the cup where those pencils drop into is 18cm in diameter but has a 4cm collision margin on each polygon -- which is much to high for a sensible sim]
  • mass can also play a role here [1kg pencils?]
  • pencils can get away with convex hull collision shapes [faster to simulate, avoids potential problems]
If I (quickly) adjust these a bit, I can get a sim that is reasonably stable:
to really dig into the "problem", here is where bullet has problems computing a normal for a tri (in your file):
btVector3& btVector3::normalize(): Assertion `!fuzzyZero()' failed.
1   raise        0x7ffff1ae4e35
2   abort        0x7ffff1acf895
3   __assert_fail_base.cold        0x7ffff1acf769
4   __assert_fail        0x7ffff1add566
5   btVector3::normalize                                     btVector3.h                     300  0x4ad934e
6   btPrimitiveTriangle::buildTriPlane                       btTriangleShapeEx.h             90   0x4afa0cc
7   btGImpactCollisionAlgorithm::collide_sat_triangles       btGImpactCollisionAlgorithm.cpp 427  0x4af72c4
8   btGImpactCollisionAlgorithm::gimpact_vs_gimpact          btGImpactCollisionAlgorithm.cpp 515  0x4af76de
9   btGImpactCollisionAlgorithm::gimpact_vs_gimpact          btGImpactCollisionAlgorithm.cpp 489  0x4af7565
10  btGImpactCollisionAlgorithm::gimpact_vs_gimpact          btGImpactCollisionAlgorithm.cpp 475  0x4af74af
11  btGImpactCollisionAlgorithm::processCollision            btGImpactCollisionAlgorithm.cpp 887  0x4af89c3
12  btCollisionDispatcher::defaultNearCallback               btCollisionDispatcher.cpp       279  0x4ad2ea7
13  btCollisionPairCallback::processOverlap                  btCollisionDispatcher.cpp       230  0x4ad3877
14  btHashedOverlappingPairCache::processAllOverlappingPairs btOverlappingPairCache.cpp      386  0x4ad0de6
15  btCollisionDispatcher::dispatchAllCollisionPairs         btCollisionDispatcher.cpp       244  0x4ad2c97
16  btCollisionWorld::performDiscreteCollisionDetection      btCollisionWorld.cpp            228  0x4ad50d7
17  btDiscreteDynamicsWorld::internalSingleStepSimulation    btDiscreteDynamicsWorld.cpp     496  0x4b31e8d
18  btDiscreteDynamicsWorld::stepSimulation                  btDiscreteDynamicsWorld.cpp     456  0x4b31d21
19  RB_dworld_step_simulation                                rb_bullet_api.cpp               212  0x4702b23
20  BKE_rigidbody_do_simulation                              rigidbody.c                     2037 0x3122bac
Anyways, this does not seem like a real bug in blender, will close...
(feel free though to comment again if you still think you've found a bug...)
Tohny (Tohny) added a comment.Jan 2 2020, 12:09 AM
Thank you for your support! I keep these tweaks in mind
