Maniphest T72872
Grease Pencil Layer Opacity not respected in some Viewport Shading Color Types
Closed, Duplicate
None
Bun ny (bunny)
Jan 3 2020, 11:55 AM
  • BF Blender
Antonio Vazquez (antoniov)
Bun ny (bunny)
Operating system: Windows 7 x64
Graphics card: NVIDIA GeForce GTX 580
Broken: 2.82 a854840e76ae
With Viewport Shading Color Type set to Object, Single or Random, Grease Pencil Layer opacity doesn't display as it does when set to Material, Vertex or Texture. Strokes with fills become totally invisible when layer opacity is set to exactly 0, and strokes without fills display at full opacity regardless of the property setting.
Create 'Monkey' Grease Pencil object, set Viewport Shading Color Type to Material, adjust layer opacity, set Color Type to Random, adjust layer opacity.
Related Objects
Mentioned Here
rBa854840e76ae: Fix T57111: Particle texture keyframes missing from Graph Editor
Bun ny (bunny) created this task.Jan 3 2020, 11:55 AM
Antonio Vazquez (antoniov) added a subscriber: Antonio Vazquez (antoniov).Jan 3 2020, 4:55 PM
This is how is designed, so we cannot consider as a bug.
When you set as Random, the colors are calculated using a random value and the original color is replaced, so the layer opacity is not used.
We are doing a refactor of the drawing engine, and this option is not defined yet, so I will merge the task into main refactor task.
Antonio Vazquez (antoniov) removed a parent task: T66293: GPencil: Redesign Blend modes and cleanup Drawing Engine.
Antonio Vazquez (antoniov) closed this task as a duplicate of T66293: GPencil: Redesign Blend modes and cleanup Drawing Engine.
