Maniphest T73082
Terminator Problem continues in 2.82 beta and 2.83 alpha
Closed, Archived
Brecht Van Lommel (brecht)
Kai (whydie)
Jan 13 2020, 10:34 AM
  • BF Blender
Kai (whydie)
William Reynish (billreynish)
Operating system: Win 10 18363.535
Graphics card: RTX 2080 Ti
v 2.81a (tested in new alpha and beta releases also)
termintor problem (pixelated pattern showing up when using bump map) showing up in cycles when using a bump map. this error has been reported in the past and stated to fixed in new versions, but upon testing these new versions. it looks like it is still present.
https://developer.blender.org/search/query/KC5P7l2DrAsu/#R
The issue tracker page linked does suggest that they've mitigated the problems in newer releases but the same thing occurs even in the 2.82 beta and 2.83 alpha so unfortunately, updating doesn't help.
attached is the blender file - the error can be seen in the shirt. upon further testing, it can also be seen in the skirt when a bump map is applied to that also. so it doesn't seem to be the model or bump map.
https://www.dropbox.com/s/ktg25ucbd9bunyu/hand%20model%20build%20up.blend?dl=0
here's an image of effect:
https://imgur.com/8fl7Nap
Kai (whydie) created this task.Jan 13 2020, 10:34 AM
William Reynish (billreynish) added subscribers: Brecht Van Lommel (brecht), William Reynish (billreynish).Jan 13 2020, 11:05 AM
Pretty sure we don't consider this a bug. Terminator issues were diminished but not entirely removed in all cases.
@Brecht Van Lommel (brecht) can you confirm?
Kai (whydie) added a comment.Jan 13 2020, 1:50 PM
@William Reynish (billreynish) Is there any simple solution to fix it, if it pops up?
William Reynish (billreynish) added a comment.Jan 13 2020, 1:51 PM
@Kai (whydie) add more geometry, reduce the bump amount are two methods.
Kai (whydie) added a comment.Jan 13 2020, 1:56 PM
Thank you! I look forward to finding out if it's a bug or not. thanks for your help
Brecht Van Lommel (brecht) closed this task as Archived.Jan 18 2020, 4:56 PM
