Maniphest T73293
Mesh Edit -> Repeat Last menu option fails for vert/edge slide (while hotkey works)
Closed, Duplicate
None
Stanislav Blinov (radcapricorn)
Jan 21 2020, 12:55 PM
  • BF Blender
Broken: 2.80, 2.81, 2.82, 2.83 (2e9d5ba2115ceabdc0e8cb2eaa148c81d7b04667)
Worked: N/A
It would appear that with vertex/edge slide, attempting to repeat them via the Edit menu doesn't do anything, while repetition works via the default Shift+R hotkey. Perhaps some other operators are also affected, encountered and tested only with slide. Could be related to T71470.
  1. Enter edit mode on the default cube.
  2. Slide a vertex.
  3. Verify that repeating via hotkey works (even though results can be puzzling, but that's subject to a different issue).
  4. Try repeating via the Edit -> Repeat Last menu entry. Repetition will not work at all.
  5. Attempt steps (2) through (4) but sliding an edge instead.
Stanislav Blinov (radcapricorn) created this task.Jan 21 2020, 12:55 PM
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Jan 21 2020, 1:04 PM
