Maniphest T73962
Grease Pencil - Stroke visible even if it is behind.
Closed, Duplicate
None
Karan (karan81s)
Feb 18 2020, 6:48 AM
  • BF Blender
  • Grease Pencil
Ankit Meel (ankitm)
Antonio Vazquez (antoniov)
Karan (karan81s)
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: GeForce 830M/PCIe/SSE2 NVIDIA Corporation 4.4.0
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: rB77d23b0bd76f
Grease Pencil - I am using "3D Location" in " Stroke depth order" (see screen shot) But still, in single object, stroke is visible in rendering or in viewport (in some cases) even if it is behind another layer.
Please see attached image.
  1. In grease pencil mode, I have created two drawings.
  2. In side view I moved them apart.
  3. In "stroke Depth order" I selected "3D Location"
  4. The stroke is still visible in rendering and in sometimes in 3D view. while rotating / zooming out etc.
Karan (karan81s) created this task.Feb 18 2020, 6:48 AM
Ankit Meel (ankitm) changed the task status from Needs Triage to Needs Information from User.Feb 18 2020, 2:08 PM
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).
Please attach a simple blend file showing the bug.
Karan (karan81s) added a comment.Feb 20 2020, 5:25 AM
Attached is the blend file.
Ankit Meel (ankitm) changed the task status from Needs Information from User to Confirmed.Feb 20 2020, 6:24 AM
In simple steps it can be done as:
  • Open the file, Click on Y, to get a flat view. note that the line is present in the circle.
  • slightly move the mouse, to change the angle. Note that the line is gone.
Ankit Meel (ankitm) added a project: Grease Pencil.Feb 20 2020, 6:25 AM
Antonio Vazquez (antoniov) closed this task as a duplicate of T66293: GPencil: Redesign Blend modes and cleanup Drawing Engine.Feb 20 2020, 8:59 AM
Antonio Vazquez (antoniov) added a subscriber: Antonio Vazquez (antoniov).
