Intel Core i7, 16 Gb RAM, NVidia GeForce 2070 RTX
Windows 10 x64
Broken: 2.83 cfdb5d9a8b07 from 2020-02-19
Worked: 2.83 5df494d75c9a from 2020-01-27
Repeat Last command stopped working for transformations like Move, Rotate and Scale, there are also problems with operations like Extrude.
- Open Blender, select default Cube and move it. Press Repeat Last and Cube will snap to its former position instead of moving again.
- Same thing happens with duplication of objects - it isn't possible to use Repeat Last because duplicates will reset to the original position.
- Sub-objects in Edit Mode also snap to their original positions if you'll try to extrude or move them around.
