Maniphest T75130
Workbench: Cull before batch creation during viewport animation rendering
Confirmed, LowDESIGN
None
Jeroen Bakker (jbakker)
Mar 27 2020, 2:00 PM
  • EEVEE & Viewport
Brecht Van Lommel (brecht)
Current Situation
When drawing an object (eg sending draw calls to the GPU) the object boundary sphere is tested against the active view). When the test fails the object isn't send to the GPU. Before this happens the GPUBatches were already generated.
When doing animation playback this could lead to the situation that the GPU Batches are calculated, but not used.
Target Situation
When using the Overlay engine/Workbench engine we could test the objects to the default view (e.g viewport). When this fails we could skip this object at all. This feature would be disabled when the shadows are turned on and only enabled when doing an image/animation render.
A consistent framerate is more important to animators then having some frames faster.
Related Objects
Jeroen Bakker (jbakker) changed the task status from Needs Triage to Confirmed.Mar 27 2020, 2:00 PM
Jeroen Bakker (jbakker) created this task.
Jeroen Bakker (jbakker) changed the subtype of this task from "To Do" to "Design".
Jeroen Bakker (jbakker) updated the task description.
Jeroen Bakker (jbakker) added a project: GPU / Viewport.Mar 27 2020, 2:06 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).Mar 27 2020, 2:07 PM
I'm not sure this is worth pursuing. The initial setup might be slower than necessary, but it's worse to have stuttering when the camera is animated or the user navigates the viewport.
Jeroen Bakker (jbakker) mentioned this in T68908: Faster Animation Playback.Mar 27 2020, 2:15 PM
Jeroen Bakker (jbakker) renamed this task from Workbench: Cull before batch creation to Workbench: Cull before batch creation during viewport animation rendering.Mar 27 2020, 3:09 PM
Jeroen Bakker (jbakker) triaged this task as Low priority.
Setting this to low prio as it would only benefit viewport animation rendering.
Jeroen Bakker (jbakker) removed a parent task: T68908: Faster Animation Playback.Apr 2 2020, 2:32 PM
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport.Jun 19 2020, 10:24 PM
Clément Foucault (fclem) moved this task from Backlog to Workbench Features on the EEVEE & Viewport board.Jun 28 2020, 12:16 AM
