Maniphest T75340
Select Circle tool selection bug
Closed, Duplicate
None
Eugene Du (APEC)
Apr 3 2020, 1:40 PM
  • BF Blender
Eugene Du (APEC)
Philipp Oeser (lichtwerk)
Graphics card: GeForce GTX 1650 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
and Blender 2.83 Alpha April 03, 01:12:10 - 6f4dbb661f10
Select Circle did not select last (or fist if only one click) selected element as highlighted current selected element.
Just select any faces with Select Circle tool and see there is no highlight last selected face as current active.
More detail short video here https://blenderartists.org/t/select-circle-tool-bug-need-comfirmation/1217357
Related Objects
Mentioned Here
T68975: lack of active object after using selection tools blocks menus
rB6f4dbb661f10: Revert "Writefile: Cleanup Scene runtime data."
Eugene Du (APEC) created this task.Apr 3 2020, 1:40 PM
Eugene Du (APEC) updated the task description.
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Apr 3 2020, 3:18 PM
Circle, Box and Lasso select dont set their selected elements active [objects, faces, verts, ...]
Afaik, this is by design, because in most situations, picking an element that should be the active one would more or less be arbitrary.
As a consequence, lots of operator that rely on an active element will fail after using these selection methods.
This is not a bug though, it is a knon issue that could be improved and has been reported before, see T68975: lack of active object after using selection tools blocks menus, will merge these reports...
Philipp Oeser (lichtwerk) closed this task as a duplicate of T68975: lack of active object after using selection tools blocks menus.Apr 3 2020, 3:18 PM
