Maniphest T75387
shift key get stuck in pan view Mac+2.82
Closed, Resolved
Ankit Meel (ankitm)
Marco Boggio Sella (boggiom72)
Apr 4 2020, 7:45 PM
  • BF Blender
Anthony Edlin (krash)
Operating system: Mojave 10.14.6
Graphics card: AMD FirePro D500 3 GB
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen) 2.76, 2.81, 2.82a still not working
When hitting shift+ MMB to pan it's no longer possible to release. It stay in pan view as if shift was permanently pressed.
In the same "pan view" state it goes when "alt" is pressed.
(Like if I select all with A then I try unselect with Alt+A for instance. It doesnt select and goes in frozen pan view mode)
It seems some inconsistencies with Mac keyboards.
Open file on Layout.
Press "shift"+ MMB to pan.
Try to exit pan view...
Marco Boggio Sella (boggiom72) created this task.Apr 4 2020, 7:45 PM
Anthony Edlin (krash) added a subscriber: Anthony Edlin (krash).Apr 4 2020, 8:05 PM
Hi, thanks for the report.
Does it happen all the time? If not it could be related to this report: T71635: Problems with Shift Key on Catalina after 4 or 5 hours of modelling.
Do you use the wacom tablet driver as mentioned in that report?
You can run blender from console with "--debug-events" and it should print out events. This may help you test the problem better. Someone will have to reproduce the problem to help fix the issue.
Marco Boggio Sella (boggiom72) added a comment.Apr 4 2020, 8:52 PM
I do have a Wacom Cintiq Pro and a screen connected. Yes,
I will try to run with debug.
Ankit Meel (ankitm) changed the task status from Needs Triage to Needs Information from User.Apr 5 2020, 1:33 PM
Marco Boggio Sella (boggiom72) added a comment.Apr 6 2020, 4:57 PM
I do I run with " ,,,debug events?"
Can you explain?
Thanks
Marco Boggio Sella (boggiom72) added a comment.Apr 7 2020, 6:35 PM
Actually Wacom had a new update which fixed the problem.
Thanks to point in that direction...
Ankit Meel (ankitm) closed this task as Resolved.Apr 7 2020, 6:46 PM
Ankit Meel (ankitm) claimed this task.
