Maniphest T75603
EEVEE render - creates a hole in the model if different materials are added in edit mode
Closed, Archived
Brecht Van Lommel (brecht)
Mohamed (mshafimd)
Apr 11 2020, 7:42 AM
  • BF Blender
  • EEVEE & Viewport
Mohamed (mshafimd)
Richard Antalik (ISS)
Svetlana (AdelanaSP)
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: GeForce GT 740M/PCIe/SSE2 NVIDIA Corporation 4.3.0
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
Creates a hole in the model if different materials are added in edit mode
How to create example file
Use the default cube of blender
in EDIT MODE - CTRL R to cut the cube in middle
CTRL B to create 2 more lines above and below the center line
select all the cube, add a material (say) Blue color
select the faces of the lines add material (say) RED color
the new added color area shows as holes instead of showing the RED color
  1. Open file
  2. Switch to rendered view
  3. Switch to Cycles engine
  4. Check with CPU and GPU device
Mohamed (mshafimd) created this task.Apr 11 2020, 7:42 AM
Svetlana (AdelanaSP) added a subscriber: Svetlana (AdelanaSP).Apr 12 2020, 1:43 PM
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Apr 14 2020, 2:54 PM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
I can not reproduce this issue.
Please make sure your GPU drivers are up to date and check if this happens when you click on File > Defaults > Load Factory Settings.
Mohamed (mshafimd) changed the task status from Needs Information from User to Needs Triage.Apr 16 2020, 7:04 AM
Hai,
I have uploaded the screen shots
it can be noted that even in cycles the situation is same with GPU etc.
I have taken 3 scenario,
  1. cycles wit GPU{F8476284}
  2. cycles with CPU{F8476286}
  3. EEVEE{F8476297}
sorry for the 1 repeat screenshot, its mistake{F8476288}
Please note that i had downloaded the zip version of the blender not the installer version.
I had extracted and using the blender 2.82 from the extracted file.
Since My laptop already has blender 2.79 and i dint want to leave that. I want both 2.79 and 2.8X series.
hope this clarifies
Mohamed (mshafimd) added a comment.Apr 16 2020, 7:20 AM
Hai,
additional info,
My GPU says its upto date,
and i set to factory setting also the same issue...
attached the GIF{F8476313} for your referance...
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from Developers.Apr 16 2020, 3:03 PM
Richard Antalik (ISS) updated the task description.
Richard Antalik (ISS) added a project: Cycles.
Brecht Van Lommel (brecht) closed this task as Archived.May 14 2020, 2:16 PM
Brecht Van Lommel (brecht) edited projects, added GPU / Viewport; removed Cycles.
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
This issue appears unrelated to Cycles. The screenshots shows a missing material in solid draw mode.
I think this is a duplicate of T71576: Viewport/crash artefacts with multiple materials and legacy NVIDIA drivers.
Installing the latest NVIDIA graphics drivers may help.
https://docs.blender.org/manual/en/latest/troubleshooting/gpu/windows/nvidia.html
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport.Jun 19 2020, 11:02 PM
