Maniphest T75641
Drag select and value enter only changes the active slider | Lattice Resolution
Closed, DuplicateKNOWN ISSUE
None
Pasang Bomjan (irex124)
Apr 12 2020, 9:25 AM
  • BF Blender
  • User Interface
Philipp Oeser (lichtwerk)
Yuro (Yuro)
Broken: version: 2.83 (sub 13), branch: master, commit date: 2020-04-08 21:23, hash: rB1239cab11ff9
In a lattice, when you drag select multiple resolution sliders and enter a value, only the active slider is updated.
Pasang Bomjan (irex124) created this task.Apr 12 2020, 9:25 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Apr 13 2020, 10:53 AM
Philipp Oeser (lichtwerk) added a project: User Interface.
Can confirm, checking...
Philipp Oeser (lichtwerk) changed the subtype of this task from "Report" to "Bug".Apr 13 2020, 10:53 AM
Philipp Oeser (lichtwerk) changed the subtype of this task from "Bug" to "Known Issue".Apr 13 2020, 1:07 PM
Undo is also weird (changing from 2 to 3 on a single axis, then Undo will change back lattice-geo, but resolution stays at 3?)
Anyways, this has to do with how rna_Lattice_update_size actually changes pntsu / pntsv / pntsw all together when changing only a single one of them.
This means that the tweak on the first UI_BUT_DRAG_MULTI buttons will set all values (overwriting what we actually want updated...)
Guess this could be fixed, it seems very isolated on the RNA handling of lattice resolution though, needs a bit more research...
Dont think I can look at this in the very near future, will change to Known Issue for now...
Julian Eisel (Severin) moved this task from Backlog to Known Issues on the User Interface board.Jun 26 2020, 3:14 PM
Philipp Oeser (lichtwerk) removed Philipp Oeser (lichtwerk) as the assignee of this task.Nov 12 2020, 12:02 PM
Yuro (Yuro) added a subscriber: Yuro (Yuro).EditedJul 19 2021, 4:58 PM
I have the same question.
And when I repeat this step many times, V and W seem to show the previous result of U.
Hans Goudey (HooglyBoogly) closed this task as a duplicate of T71397: Lattice UVW input Glitch.Jul 19 2021, 6:15 PM
