Maniphest T76035
Object flickering when clicking in both Object and Edit mode [v2.90a]
Closed, ResolvedBUG
Clément Foucault (fclem)
Thiago Sampaio (thsampa)
Apr 24 2020, 1:54 AM
  • BF Blender
  • EEVEE & Viewport
  • Platform: macOS
Sebastian Parborg (zeddb)
Sebastián Barschkis (sebbas)
William Reynish (billreynish)
Óscar (Oxer)
Operating system: MacOS Mojave 10.14.6 (18G95) | Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 580X OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.20
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-04-23 21:08, hash: rB826f6dd9ee20
When I click an object it flickers back and forth between transparent and preview and the edges look broken. Not sure if this is normal in 2.90a or an actual bug
Basically create a mesh and start clicking the object in object mode, and edit mode, the faces, edges and vertices.
Thiago Sampaio (thsampa) created this task.Apr 24 2020, 1:54 AM
Thiago Sampaio (thsampa) added a comment.Apr 24 2020, 2:06 AM
I realized that I wasn't using the default theme so I changed it back from Maya to Default and the problem still occurs.
Sebastian Parborg (zeddb) changed the task status from Needs Triage to Needs Information from Developers.Apr 24 2020, 11:45 AM
Sebastian Parborg (zeddb) added a project: GPU / Viewport.
Sebastian Parborg (zeddb) added subscribers: Sebastián Barschkis (sebbas), Sebastian Parborg (zeddb).
I can't reproduce this on linux.
@Sebastián Barschkis (sebbas) can you reproduce this on your intel Mac?
Sebastián Barschkis (sebbas) added a comment.Apr 24 2020, 11:52 AM
@Sebastian Parborg (zeddb) Cannot reproduce this either. I am on macOS 10.15.4 though, so maybe that has to do with it ..
Sebastian Parborg (zeddb) added a subscriber: William Reynish (billreynish).Apr 24 2020, 12:57 PM
@William Reynish (billreynish) can you reproduce this on your Mac?
William Reynish (billreynish) added a comment.Apr 24 2020, 2:11 PM
Cannot reproduce on any of my 3 Macs here, neither on integrated graphics nor with AMD.
Óscar (Oxer) added a subscriber: Óscar (Oxer).EditedApr 24 2020, 3:04 PM
This happens in my iMac 2011 with macos 10.13.6 / AMD Radeon HD 6970M & blender-2.90-69b6c89842ff
Sebastian Parborg (zeddb) added a comment.Apr 24 2020, 4:30 PM
@Óscar (Oxer) your GPU is too old and not supported by blender.
@Thiago Sampaio (thsampa) are you able to see if this is solved if you use newer OSX releases?
As we can't seem to reproduce this, it is probably GPU driver bugs you are running into.
Thiago Sampaio (thsampa) added a comment.Apr 24 2020, 4:48 PM
Not at the moment. I'm using this OS because of other software I use professionally that still haven't shaken all the kinks in Catalina. So to avoid problems, I'm hanging on to this OS for few more weeks.
In the meantime I'm hoping someone else with the same OS will complain of the same problem eventually.
Do you guys know of anyone that uses the same GPU I use and has no problems at all with 2.90a?
William Reynish (billreynish) added a comment.Apr 24 2020, 5:05 PM
I'm still only on Mojave on two Macs here, the third one is on Catalina. None of them have the issue described here. One of them is an old iMac from 2015.
Thiago Sampaio (thsampa) added a comment.Apr 24 2020, 5:20 PM
Damn, please don't make me update my OS, at least not now. :P
Óscar (Oxer) added a comment.Apr 24 2020, 5:21 PM
On Blender 2.83.13 all work fine
I can't install newer macOS because to the configuration of my iMac.
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport.Jun 19 2020, 10:23 PM
Clément Foucault (fclem) changed the subtype of this task from "Report" to "Bug".Jul 2 2020, 1:27 AM
Clément Foucault (fclem) added a project: Platform: macOS.
Clément Foucault (fclem) moved this task from Backlog to Blender 2.90 on the EEVEE & Viewport board.
Clément Foucault (fclem) added a subscriber: Clément Foucault (fclem).
  • Can you check if that happens in you change the antialiasing method in the user preference > viewport.
  • Does that happen even if you are in other shading modes?
Clément Foucault (fclem) closed this task as Resolved.Nov 23 2020, 1:28 PM
Clément Foucault (fclem) claimed this task.
Also please try with the latest beta to see if this has not been fixed yet.
