Maniphest T76136
Unable to untoggle fullscreen mode if it was enabled in startup file
Closed, Archived
None
Bohdan Lvov (ostapblender)
Apr 26 2020, 11:23 PM
  • BF Blender
  • User Interface
Alaska (Alaska)
Dalai Felinto (dfelinto)
Harley Acheson (harley)
Richard Antalik (ISS)
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-04-25 17:40, hash: rBf418eddf8e1c
Worked: Can't find any, earliest version which I've tried was 2.74 and it behaves the same.
If user enable full screen mode and save this scene as a startup file, it wouldn't be possible to return Blender to the windowed mode after the start from this file. If scene was changed and then user trying to disable fullscreen, it's impossible to close Blender, since it's apparently asking if file should be saved and the window itself never appearing.
Demo: https://youtu.be/Ih56mCo_3ks
As you can see from the video, new preview of this window aren't rendering, so there's literally no window anymore.
  1. Press Window -> Toggle Window Fullscreen
  2. Save startup file
  3. Restart Blender
  4. Toggle Window Fullscreen
Congrats, it's stuck and can be only closed through Task Manager.
Bohdan Lvov (ostapblender) created this task.Apr 26 2020, 11:23 PM
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from Developers.EditedApr 27 2020, 12:47 AM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
Unable to reproduce on Linux with a GTX 1050Ti. May be a Windows bug
Harley Acheson (harley) added a subscriber: Harley Acheson (harley).Apr 27 2020, 5:00 AM
Richard Antalik (ISS) changed the task status from Needs Information from Developers to Needs Information from User.Apr 28 2020, 10:11 PM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
I can not reproduce this as well
@Bohdan Lvov (ostapblender) can you try to wipe user preferences and check if that helps?
You can do that by pressing start and type %appdata% hit enter and rename folder Blender Foundation
Harley Acheson (harley) added a comment.Apr 28 2020, 11:26 PM
I haven't been able to reproduce this either. The instructions above only include "Toggle Window Fullscreen", while the video also shows that the 3DView Editor is "Maximize Area" as well (You can see the "back to previous" button. But I can't find any combination of Maximize and Fullscreen that results in what OP reports.
Bohdan Lvov (ostapblender) added a comment.EditedApr 28 2020, 11:43 PM
I've tried it with all the mentioned versions and still not luck: https://youtu.be/ljPoA9lPJIs
Oh, and it's also has that frozen image of a fullscreen in the alt tab window, if it's helpful anyhow
Richard Antalik (ISS) added a comment.Apr 29 2020, 5:38 AM
Interesting.
@Bohdan Lvov (ostapblender) can you press Win+right key few times when Blender window dissappears? If that does nothing, try Win+up key.
Bohdan Lvov (ostapblender) added a comment.Apr 29 2020, 4:13 PM
In T76136#919718, @Richard Antalik (ISS) wrote:
Interesting.
No effect, unfortunately. Looks like since I can't select Blender window, it doesn't react to this shortcuts. If Blender was opened not in the fullscreen mode, but I'll turn it on and then press Win+Down to disable it - nothing seemingly happening, BUT I have to press "Toggle Window Fullscreen" to disable it twice. It fullscreen saved in startup file Win+Down leading to the same effect as just clicking on "Toggle Window Fullscreen" - window disappearing and not selectable anymore. I've tried to disable second display with no luck - behavior was exactly the same.
Richard Antalik (ISS) added a comment.Apr 29 2020, 7:43 PM
@Bohdan Lvov (ostapblender) are you saying, that if you don't do any changes to scene, there are no problems?
Can you try disabling autohide on start panel and also move it to bottom of the screen?
Bohdan Lvov (ostapblender) added a comment.Apr 29 2020, 8:03 PM
I'm still unable to retrieve Blender window, but at least it's possible to close it without task manager.
Sure, although it didn't change anything https://www.youtube.com/watch?v=5i1N5QZHFPc
Richard Antalik (ISS) updated the task description.Apr 29 2020, 8:33 PM
Richard Antalik (ISS) added a project: User Interface.
Richard Antalik (ISS) changed the task status from Needs Information from User to Needs Information from Developers.Apr 29 2020, 8:40 PM
Thanks for info. I have no more questions, but neither ideas what could cause this issue.
I think it is unlikely, that there is bug in Blender involved here. Possibly some 3rd party software or some weird OS/driver setting that could cause this. Unfortunately there is no easy way to check for this. @Bohdan Lvov (ostapblender) if you can investigate this further and poke at things on your side I think would help and possibly even resolve this problem.
Richard Antalik (ISS) added a comment.Nov 26 2020, 7:41 PM
@Bohdan Lvov (ostapblender) I am looking at older reports, is this still an issue? Or have anything changed?
Dalai Felinto (dfelinto) closed this task as Archived.Jan 18 2021, 12:28 PM
Dalai Felinto (dfelinto) added a subscriber: Dalai Felinto (dfelinto).
