Maniphest T76142
Blender 2.82a Collada export crash
Closed, Duplicate
None
Rod Jenkins (kissmecomix)
Apr 27 2020, 5:29 AM
  • BF Blender
Ankit Meel (ankitm)
Brecht Van Lommel (brecht)
Richard Antalik (ISS)
Graphics card: AMD Radeon HD 8210 ATI Technologies Inc. 4.5.13399 Core Profile Context 15.200.1065.0
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
Blender crashes upon the export of a fully rigged character in the .dae (collada) file format, the files does export, but it is corrupted
should note. the character is an import of a .mhx file
Files> Export> Collada
use blender filename> Save
Rod Jenkins (kissmecomix) created this task.Apr 27 2020, 5:29 AM
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).EditedApr 28 2020, 3:48 PM
I get this, and no crash.
Collada export: image does not exist:
//textures/afro_diffuse.png
//textures/brown_eye.png
//textures/eyebrow011.png
//textures/young_darkskinned_female_diffuse.png
Bountyh2_3d_naked:Body: material with index 1 is not used.
Collada export to: /Users/ankit/Downloads/bountyhblend2a.dae
Saved session recovery to '/var/folders/gq/_h_6mn_90vl50xxh1zgrvjz40000gn/T/quit.blend'
Error: Not freed memory blocks: 7, total unfreed memory 0.002518 MB
Blender quit
Program ended with exit code: 0
The dae:
looks a bit glitchy in the torso
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).Apr 28 2020, 5:06 PM
There is a chance this is related to T76113: Crash closing file browsers with AMD GPUs, in which case upgrading to the latest graphics drivers can help, since version 15.200.1065.0 is from 2015.
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).Apr 28 2020, 10:48 PM
Can confirm memleak, not crash
BKE_scene_objects_iterator_begin len: 40 000000002A7A3938
BKE_scene_objects_iterator_begin len: 64 000000003334B138
memory pool len: 48 000000002A7A21D8
BLI_Mempool Chunk len: 1016 00000000332B3028
BKE_scene_collections_iterator_begin len: 24 000000002994E968
CollectionArray len: 40 000000002A7A1DB8
ghash_buckets_resize len: 88 00000000335C62A8
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Apr 28 2020, 10:49 PM
@Rod Jenkins (kissmecomix) Please update GPU drivers and let Us know if that helps
Rod Jenkins (kissmecomix) added a comment.Apr 29 2020, 2:02 AM
I will try, however, the last time i tried to update the driver, my screen kept flicking off and on and I had to revert. so if it is the driver, then i"m stuck
Rod Jenkins (kissmecomix) claimed this task.Apr 29 2020, 10:43 PM
Graphics card: AMD Radeon HD 8210 ATI Technologies Inc. 4.5.13587 Core Profile Context 20.2.2 26.20.15019.19000
I did update the driver, as you can see, and blender still crashes as I try to export a file in the .dae format, what other information would you need??
Ankit Meel (ankitm) changed the task status from Needs Information from User to Needs Triage.Apr 30 2020, 6:03 AM
Ankit Meel (ankitm) removed Rod Jenkins (kissmecomix) as the assignee of this task.
Ankit Meel (ankitm) added a comment.EditedApr 30 2020, 10:28 AM
can you test by opening Preferences window and then closing it to see if it crashes.
Also, is it specific to this file and Collada ? On default cube, hit File menu > open, wait for 4-5 seconds and without doing anything, close it. Does it crash now ?
Richard Antalik (ISS) added a comment.Apr 30 2020, 6:28 PM
From what I can see, this is the same issue as T76113. Will merge for now assuming that driver update wouldn't help there either.
Richard Antalik (ISS) closed this task as a duplicate of T76113: Crash closing file browsers with AMD GPUs.Apr 30 2020, 6:28 PM
Rod Jenkins (kissmecomix) added a comment.May 1 2020, 8:07 PM
I can go to preferences with no problem
The issue is only applies to exporting any project to the Collada format.
and even bringing up blender up for a few seconds shutting it down then bringing back up doesn't resolve the issue.
weirdness.
Richard Antalik (ISS) added a comment.May 18 2020, 10:20 AM
@Rod Jenkins (kissmecomix) I want to check if this problem is really resolved, since you mentioned that this happens only when exporting to collada. But I wanted first T76113 to be closed.
