Maniphest T76212
Avoid Dynamic Menu Contents
Confirmed, NormalDESIGN
None
Apr 29 2020, 6:26 AM
  • User Interface
William Reynish (billreynish)
This tasks proposes that dynamic menu contend could not be used (with some exceptions, below).
Examples of dynamic menu content are menu items that are shown or not based on the number of selected items, an operators poll function, or the saved state of the blend file.
This causes the following problems:
  • Causes User Uncertainty
    When you remember a menu item being available and find it missing, it's not obvious whats happening.
    If the menu item is greyed out, it makes it obvious the functionality exists but isn't available.
    Note that Blender has the ability to set a message for why an operator is disabled which is displayed in the tool-tip (this should be used more often).
  • Complicates Documentation
    When instructions give steps to perform an action, a user may find the menu item missing, and think they're using the wrong version or the instructions require and add-on or some other customization.
  • Changes Key Accelerators
    When menu items change are added/removed, the short-cut keys to activate an item will change too, so a user can't use muscle memory to activate a menu item.
  • Complicates Menu Memory
    Currently popup menus remember the last action based on the text, with dynamic changing text, our menu hashing function ui_popup_menu_memory would need to somehow support this too, at least if this is used for menu items in popup menus.
    Note that even in the case this was solved for updated display-text, moving menu items around has inherent problems with remembering the last used action.
Exceptions
  • Context Menu.
  • Quick Favorites Menu.
  • Menu's that Expand Data such as "Open Recent" or Add "Collection Instances"
Related Objects
StatusSubtypeAssignedTask
ConfirmedDESIGNNone
ArchivedDESIGNWilliam Reynish (billreynish)
ConfirmedDESIGNNone
ConfirmedDESIGNNone
Campbell Barton (campbellbarton) changed the task status from Needs Triage to Confirmed.Apr 29 2020, 6:26 AM
Campbell Barton (campbellbarton) created this task.
Campbell Barton (campbellbarton) mentioned this in T76211: User Interface Policies.Apr 29 2020, 6:29 AM
Brecht Van Lommel (brecht) added a project: User Interface.Apr 29 2020, 7:55 AM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).Apr 29 2020, 10:57 AM
The obvious exceptions are the context menus and the user-defined Quick Favorites.
Campbell Barton (campbellbarton) updated the task description.Apr 29 2020, 2:39 PM
Campbell Barton (campbellbarton) updated the task description.May 7 2020, 2:20 AM
Julian Eisel (Severin) changed the subtype of this task from "Report" to "Design".May 18 2020, 4:59 PM
Julian Eisel (Severin) moved this task from Backlog to Human Interface Guidelines (HIG) on the User Interface board.Jun 25 2020, 12:11 PM
