Maniphest T76220
vertices are not merging
Closed, Archived
Ankit Meel (ankitm)
Bhavith Shetty (Bhavith21)
Apr 29 2020, 10:54 AM
  • BF Blender
Ankit Meel (ankitm)
William Reynish (billreynish)
Operating system:Windows 10 pro
Graphics card: Geforce GT 730 , Nvidia compatible
Broken: 2.82a
Worked:
when i press alt+m its showing merge vertices and i select *at centre* option its not merging
Related Objects
Bhavith Shetty (Bhavith21) created this task.Apr 29 2020, 10:54 AM
William Reynish (billreynish) changed the task status from Needs Triage to Needs Information from User.Apr 29 2020, 10:55 AM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).
Please provide an example blend file that demonstrates the issue. Thanks.
William Reynish (billreynish) merged a task: T76219: vertices are not merging .Apr 29 2020, 10:55 AM
Bhavith Shetty (Bhavith21) added a comment.Apr 29 2020, 2:21 PM
when i press alt +m for at centre merge
Ankit Meel (ankitm) closed this task as Archived.May 6 2020, 3:09 PM
Ankit Meel (ankitm) claimed this task.
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).
https://docs.blender.org/manual/en/latest/modeling/meshes/editing/vertices.html#vertex-merging
doesn't look like you can merge two vertices from distinct (unconnected) vertices. If you select two more on each side, you get this:
If you think there's a bug, not a feature request, please comment.
