Maniphest T76224
Grid Fill Offset function doesn't work (regression since b1037aa88fed)
Closed, ResolvedBUG
Chingiz Jumagulov (Krayzmond)
Apr 29 2020, 11:33 AM
  • BF Blender
  • Modeling
Alaska (Alaska)
Madani Arsyad Zainal Ilmi (madani_arsyad)
Pasang Bomjan (irex124)
Philipp Oeser (lichtwerk)
Sergey (borschberry)
Operating system: Windows 10, 64 bits
Graphics card: Nvidia Geforce 1080 8 gb, Nvidia Geforce 1070, 8gb
Broken: rBb1037aa88fed: Fix T76148: Grid fill crashes with multiple connected loops
Worked: rBb1037aa88fed ^
Hello dear blender developers! I have noticed that in recent Blender 2.83 builds Grid Fill Offset (Found in Mesh Edit mode) function does not work at all. Please, could you fix that bug, I use this function a lot. Thank you for your awesome work, 2.83 is awesome, especially new undo!
  1. Create Cylinder
  2. Delete one of the caps of the cylinder
  3. Press Ctrl + F and select Grid fill
  4. Mess around with options, see that Grid Fill Offset function does not work.
Below is the video of the bug, Comparing it with 2.82a. As you can see in 2.83 Grid Fill Offset function does not work at all:
Revisions and Commits
rB Blender
Related Objects
Mentioned Here
T76148: Grid Fill problem
rB13abd3784ad0: Merge branch 'blender-v2.83-release'
rB3d7ac7feba17: Merge branch 'blender-v2.83-release'
rBS1dd4e933d817: Fix grid-fill offset option
Chingiz Jumagulov (Krayzmond) created this task.Apr 29 2020, 11:33 AM
Pasang Bomjan (irex124) changed the task status from Needs Triage to Needs Information from User.Apr 29 2020, 11:43 AM
Pasang Bomjan (irex124) added a subscriber: Pasang Bomjan (irex124).
Have you tried the latest alpha from https://builder.blender.org/download/
It works for me in 2.90.
Alaska (Alaska) added a subscriber: Alaska (Alaska).Apr 29 2020, 1:07 PM
Grid fill offset doesn't work for me in 2.90 3ea67e08fe8e (2020-04-28 21:49).
Chingiz Jumagulov (Krayzmond) changed the task status from Needs Information from User to Needs Triage.Apr 29 2020, 4:25 PM
The bug is related to 2.83 beta version why would you mark it as needs information for user? Please Read bug instructions carefully, it is related to Grid Fill Offset function specifically. And Grid Fill Offset also does not work properly in 2.90 as well by the way even with clean install and factory reset. Please look at the video attached to this specific bug and read the steps carefully.
Chingiz Jumagulov (Krayzmond) added a comment.Apr 29 2020, 4:32 PM
This comment was removed by Chingiz Jumagulov (Krayzmond).
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Apr 29 2020, 9:31 PM
Philipp Oeser (lichtwerk) added a project: Modeling.
Can confirm, checking...
(assume this is caused by rBb1037aa88fed: Fix T76148: Grid fill crashes with multiple connected loops / rB3d7ac7feba17: Merge branch 'blender-v2.83-release')
Pasang Bomjan (irex124) added a comment.EditedApr 29 2020, 9:32 PM
Last working 2.90 build for me : 2020-04-26 22:57, hash: `rB13abd3784ad0
Philipp Oeser (lichtwerk) triaged this task as High priority.Apr 29 2020, 10:08 PM
Philipp Oeser (lichtwerk) updated the task description.
Philipp Oeser (lichtwerk) added a subscriber: Campbell Barton (campbellbarton).
Marking as High since this is a recent regression.
@Campbell Barton (campbellbarton) : mind checking?
Philipp Oeser (lichtwerk) renamed this task from Grid Fill Offset function doesn't work in Blender 2.83 to Grid Fill Offset function doesn't work (regression since b1037aa88fed).Apr 29 2020, 10:10 PM
Ankit Meel (ankitm) added a subscriber: Sergey (borschberry).
Campbell Barton (campbellbarton) closed this task as Resolved by committing rB36ad59b550a2: Fix T76224: Grid fill offset doesn't work.May 5 2020, 5:45 AM
Campbell Barton (campbellbarton) claimed this task.
Campbell Barton (campbellbarton) added a commit: rB36ad59b550a2: Fix T76224: Grid fill offset doesn't work.
Campbell Barton (campbellbarton) merged a task: T76492: grid fill Ofsset control is not working.May 7 2020, 4:57 AM
Campbell Barton (campbellbarton) added a subscriber: Madani Arsyad Zainal Ilmi (madani_arsyad).
