Maniphest T76237
Display as wireframe for mesh object makes the object difficult to select ( object properties > viewport display>display as>wireframe )
Closed, Archived
Ankit Meel (ankitm)
Godwin Jimoh (Astronet)
Apr 29 2020, 6:00 PM
  • Add-ons (Community)
  • BF Blender
Ankit Meel (ankitm)
Hamidov (Hamlo)
Richard Antalik (ISS)
Operating system: Windows 10 64-bit
Graphics card: Intel(R) HD Graphics 520
Broken: 2.82a
Mesh object becomes impossible to select when Its viewport display is set to wireframe. the object can only be selected only through the outliner or directly on t's origin (that is if the origin point is visible
  • select the cube object
  • change the display-as option in the viewport display tab of object properties from texture to wireframe
  • unselect the cube
  • try to select the cube again by clicking on an edge( does not work)
Godwin Jimoh (Astronet) created this task.Apr 29 2020, 6:00 PM
Godwin Jimoh (Astronet) updated the task description.
Ankit Meel (ankitm) added subscribers: Hamidov (Hamlo), Ankit Meel (ankitm).
common thing is HD 520
Godwin Jimoh (Astronet) added a project: BF Blender.Apr 29 2020, 10:02 PM
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Apr 29 2020, 11:18 PM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
Newest driver seems to be Date: 04/27/2020 Version: 26.20.100.8141 (Latest)
Can you update driver and check if this resolves the issue?
Hamidov (Hamlo) added a comment.Apr 30 2020, 5:15 PM
This comment was removed by Hamidov (Hamlo).
Ankit Meel (ankitm) closed this task as Archived.May 8 2020, 10:55 AM
Ankit Meel (ankitm) claimed this task.
Thanks again for the report. If the problem persists please open a new report after updating GPU drivers and testing on file > defaults > load factory settings.
