Maniphest T76292
Crash after adding texture with node open button
Closed, Duplicate
None
Sergey Sidun (DonKehhot)
May 1 2020, 9:55 AM
  • BF Blender
Ankit Meel (ankitm)
Operating system: Linux-5.6.8-arch1-1-x86_64-with-arch-Arch-Linux 64 Bits
Graphics card: Radeon RX 570 Series (POLARIS10, DRM 3.36.0, 5.6.8-arch1-1, LLVM 10.0.0) X.Org 4.6 (Core Profile) Mesa 20.0.6
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
Blender crashes after adding texture in a node tree with open button. I noticed that it doesn't happen if I just drag-n-drop texture in shader editor. It writes Segmentation fault or Buffer overflow depending of debug option I use. I tried all experimental versions and bug still exists there as well. The last version of blender where everything are stable is 2.80rc3 (from official site).
After a while I tried to install blender 2.82a from arch repository to test and it is actually not crashing. So it only affects steam version and blender from official site.
I want to confirm that crashes occur on arch repository version too. It just takes longer time.
I'm not sure if I should write about this bug here so it can be something with my OS.
  1. Open blender default scene
  2. Go to a Shading tab
  3. Add a texture with Image Texture node using Open button
Sergey Sidun (DonKehhot) created this task.May 1 2020, 9:55 AM
Ankit Meel (ankitm) closed this task as a duplicate of T76193: Crash when loading image texture.May 1 2020, 10:01 AM
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).
you may please add a concise comment with the two log files there in T76193.
this is a good observation too.
Sergey Sidun (DonKehhot) updated the task description.May 2 2020, 3:18 AM
