Maniphest T76307
Blender 2.83beta crashes right after closing Preferences dialog on Fedora 32
Closed, Duplicate
None
Anton Raves (Memento)
May 1 2020, 8:30 PM
  • BF Blender
Ankit Meel (ankitm)
Brecht Van Lommel (brecht)
Operating system: Linux-5.6.7-300.fc32.x86_64-x86_64-with-fedora-32-Thirty_Two 64 Bits
Graphics card: AMD JUNIPER (DRM 2.50.0 / 5.6.7-300.fc32.x86_64, LLVM 10.0.0) X.Org 3.3 (Core Profile) Mesa 20.0.5
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-04-29 08:26, hash: rB839fe335d2d6
Blender 2.83 (sub 15) crashes right after closing Preferences dialog on Fedora 32.
Download the Blender 2.83 (sub 15) from the buildbot environment, launch it directly or from the Terminal using
/opt/blender/blender --debug
Under the "File"-menu select "Defaults" and then "Load Factory Settings" to begin fresh. Now go to the "Edit"-menu and select "Preferences". It doesn't matter if chanes are made there or not, click "Save Preferences" and close the Preferences-window. Now it will take a few seconds in which the mouse can be moved and such, after which clicking the mouse will not be registered anymore and Blender itself crashes. The Terminal then contains the following lines:
[machinename@macpro ~]$ /opt/blender/blender --debug
Switching to fully guarded memory allocator.
Build: 2020-04-29 08:47:09 Linux Release
argv[0] = /opt/blender/blender
argv[1] = --debug
Read prefs: /home/machinename/.config/blender/2.83/config/userpref.blend
read file /home/machinename/.config/blender/2.83/config/startup.blend
  Version 283 sub 15 date 2020-04-29 08:26 hash 839fe335d2d6
found bundled python: /opt/blender/2.83/python
read file
  Version 280 sub 39 date unknown hash unknown
Writing userprefs: '/home/machinename/.config/blender/2.83/config/userpref.blend' ok
Writing: /tmp/blender.crash.txt
Segmentation fault (core dumped)
And the /tmp/blender.crash.txt file contains the following lines:
# Blender 2.83 (sub 15), Commit date: 2020-04-29 08:26, Hash 839fe335d2d6
# backtrace
/opt/blender/blender(BLI_system_backtrace+0x1d) [0x69841ad]
/opt/blender/blender() [0xc14bb2]
/lib64/libc.so.6(+0x3cab0) [0x7f42923cdab0]
/usr/lib64/dri/r600_dri.so(+0x5b4d6e) [0x7f4265a88d6e]
/usr/lib64/dri/r600_dri.so(+0x6ddc63) [0x7f4265bb1c63]
/usr/lib64/dri/r600_dri.so(+0x125f5e) [0x7f42655f9f5e]
/usr/lib64/dri/r600_dri.so(+0x128213) [0x7f42655fc213]
/usr/lib64/dri/r600_dri.so(+0x133794) [0x7f4265607794]
/usr/lib64/dri/r600_dri.so(+0x13078e) [0x7f426560478e]
/usr/lib64/dri/r600_dri.so(+0x122b62) [0x7f42655f6b62]
/usr/lib64/dri/r600_dri.so(+0x357b4d) [0x7f426582bb4d]
/usr/lib64/dri/r600_dri.so(+0x357c05) [0x7f426582bc05]
/opt/blender/blender(immEnd+0x2f9) [0x5690a49]
/opt/blender/blender(ED_region_do_draw+0xbaa) [0x121f44a]
/opt/blender/blender(wm_draw_update+0x52d) [0xec287d]
/opt/blender/blender(WM_main+0x30) [0xec0820]
/opt/blender/blender(main+0x321) [0xb4b7d1]
/lib64/libc.so.6(__libc_start_main+0xf2) [0x7f42923b8042]
/opt/blender/blender() [0xc113dc]
Anton Raves (Memento) created this task.May 1 2020, 8:30 PM
Anton Raves (Memento) added a comment.May 1 2020, 9:04 PM
Problem also exists in the official Blender 2.82a release, on the same system, after having deleted the complete ~/.config/blender directory...
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).May 1 2020, 10:08 PM
Anton Raves (Memento) added a comment.May 1 2020, 10:30 PM
Additional info: Didn't have this issue under Fedora 31... And Blender 2.79 doesn't have this problem while being under Fedora 32
Ankit Meel (ankitm) closed this task as a duplicate of T76113: Crash closing file browsers with AMD GPUs.May 2 2020, 11:54 AM
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).
