Maniphest T76336
Radeon GPU crashes while rendering
Closed, Duplicate
None
EMILIO (FILOS-BLENDER)
May 2 2020, 7:17 PM
  • BF Blender
  • Platform: macOS
  • Render Pipeline
  • EEVEE & Viewport
Ankit Meel (ankitm)
Brecht Van Lommel (brecht)
Nombre del modelo: MacBook Pro
Identificador del modelo:	MacBookPro15,3
Nombre del procesador:	6-Core Intel Core i9
Velocidad del procesador:	2,9 GHz
Cantidad de procesadores:	1
Cantidad total de núcleos:	6
Caché de nivel 2 (por núcleo):	256 KB
Caché de nivel 3:	12 MB
Tecnología Hyper-Threading:	Activado
Memoria:	32 GB
Versión de la ROM de arranque:	1037.100.362.0.0 (iBridge: 17.16.14281.0.0,0)
Radeon Pro Vega 20:
Modelo de chipset:	Radeon Pro Vega 20
Tipo:	GPU
Bus:	PCIe
Anchura de canal PCIe:	x8
VRAM (total):	4 GB
Fabricante:	AMD (0x1002)
ID del dispositivo:	0x69af
ID de la revisión:	0x00c0
Revisión de la ROM:	113-D2060I-087
Versión de VBIOS:	113-D20601MA0T-016
Versión de la ROM de opción:	113-D20601MA0T-016
Versión del driver EFI:	01.01.087
Cambio automático de modalidad de gráficos:	Compatible
Versión gMux:	5.0.0
Metal:	Compatible, familia de funciones macOS GPUFamily2 1
Pantallas:
Blender 2.8a
Radeon Prorender 2.3.4
Hello the system crashes when I work with Radeon pororender, I try to use this render engine to take advantage of my gpu. The problem is that I am not able to use radeon more than five minutes without my system crashing.
I’m enclosing an image capture that, if I understand correctly, says that I have an incompatibility problem between Intel HD and radeon, is that right? , if so then I guess the problem is Radeon or macOS? Thank you very much for your time and congratulations for Blender, a daily cad program I admire more.
Emilio
EMILIO (FILOS-BLENDER) created this task.May 2 2020, 7:17 PM
Ankit Meel (ankitm) renamed this task from When I try to change cycles for radeon the system falls down, in amd forums I don’t get answers. to Radeon GPU crashes while rendering .May 2 2020, 9:14 PM
Ankit Meel (ankitm) updated the task description.
Ankit Meel (ankitm) added projects: Platform: macOS, GPU / Viewport, Render Pipeline.
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).May 2 2020, 9:16 PM
Brecht Van Lommel (brecht) closed this task as a duplicate of T76329: Radeon didn’t work for me in any version of Blender.May 2 2020, 9:43 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Please see the reply in the other task. The Blender project does not develop or provide support for Radeon ProRender, any issues should be reported to AMD.
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport.Jun 19 2020, 11:02 PM
