Maniphest T76348
Addon-Gear or Bolts > fatal error
Closed, Duplicate
None
Donald Silva (i080457)
May 2 2020, 11:26 PM
  • Add-ons (Community)
Operating system: Windows 10
Graphics card:
Broken: 2.82 ( tried reinstalling on May 2 - same issue)
no other technical information on version or date shows on splash screen
Add either Gears or Bolts> fatal errors
3D Viewport
no other meshes involved
Object Mode
Add > Mesh > Gears > Gear
  1. several error messages appear (see System Console dump below)
  2. a default gear does get generated
  3. but system won't respond after
Read prefs: C:\Users\Don\AppData\Roaming\Blender Foundation\Blender\2.82\config\userpref.blend
found bundled python: C:\Program Files\Blender Foundation\Blender 2.82\2.82\python
Warning: property 'release_confirm' not found in keymap item 'OperatorProperties'
File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\scripts\addons\add_mesh_extra_objects\add_mesh_gears.py", line 749, in invoke
  self.execute(context)
File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\scripts\addons\add_mesh_extra_objects\add_mesh_gears.py", line 714, in execute
  tipGroup.add(verts_tip, 1.0, 'ADD')
RuntimeError: Error: VertexGroup.add(): cannot be called while object is in edit mode
Donald Silva (i080457) created this task.May 2 2020, 11:26 PM
Robert Guetzkow (rjg) closed this task as a duplicate of T76049: Errors after adding a Gear or Worm (extra objects).May 2 2020, 11:29 PM
